Performed IS250 Spark plug change.
Old 02-28-17, 06:28 PM
dnwin
dnwin's Avatar
Default Performed IS250 Spark plug change.
It was a success! But now Driver window panel does not work for any other windows. I only could control my window side. Has this happened to anyone else? Please help me trouble shoot! Yes I removed the battery when I performed this.
Old 02-28-17, 06:40 PM
bangdangvn
bangdangvn's Avatar
You can find this in the sticky section but here you go
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/291026-electrical-help-windows-won-t-roll-up-after-battery-disconnect-2.html
Old 02-28-17, 06:42 PM
MikeyK02
MikeyK02's Avatar
Gonna go off memory here...you have to reprogram your window. Press start button but don't turn engine on.
Roll drivers window half way down (not with automatic lower) but with your finger controling power...roll back up and hold for 3 seconds
Reach over to passenger window..this time roll all the way down...then back up....keep holding button up for 3-5 secs...
Repeat with other two windows..
You have to use each window switch from the door its on...then youre set
Old 02-28-17, 08:55 PM
krastopher
krastopher's Avatar
What causes it to lose memory on the windows?
Old 03-01-17, 06:06 AM
dnwin
dnwin's Avatar
thanks everyone ! I appreciate it !
Old 03-03-17, 02:13 PM
Gville350
Gville350's Avatar
OP said they "removed" or disconnected the battery when doing this DIY project. Since the battery feeds all of the various ECUs in the car their power when off, the memory of the auto-down/auto-up function is lost every time you disconnect the battery from the car..
Ringming
09-26-18 09:40 AM
Leines
RX - 1st Gen (1999-2003)
05-08-12 01:22 AM
dbaze25
05-27-11 01:53 AM
Lexminster
01-16-11 09:01 PM
Kuki_350
07-27-08 10:32 AM
Quick Reply: Performed IS250 Spark plug change.
