Would this work?
Old May 15, 2015 | 02:45 PM
jjc250's Avatar
jjc250
Default Would this work?
For my 07, I want to get this and play music from my USB. Would it work? Would I be able to control the songs from my steering wheel controls?
http://www.ebay.com/itm/3-5mm-Male-audio-aux-to-USB-2-0-A-male-M-M-adapter-Charge-Cable-USA-Seller-/281161085354?pt=LH_DefaultDomain_0&hash=item417681b1aa
Thanks!
Old May 17, 2015 | 08:40 AM
Gville350's Avatar
Gville350
Yes, you would be able to receive the audio signal through the 3.5mm port there; but you would not gain any steering wheel controls.
Old May 17, 2015 | 12:34 PM
nosurprise's Avatar
nosurprise
I don't see how it's possible to get music from a normal USB cable. Reading the description on eBay, it says it's not for music.
Old May 17, 2015 | 01:36 PM
jjc250's Avatar
jjc250
Thank you both for the reply. I think I'll just purchase a regular AUX cable and hook it up to my iPod. And I'd assume that through AUX cable, the steering wheel controls would work?
Old May 17, 2015 | 08:12 PM
chitotafy's Avatar
chitotafy
Im 99.9% sure you will NOT be able to control your steering wheel audio from an aux cable. Lets make that 100%
Old May 17, 2015 | 08:56 PM
Bichon's Avatar
Bichon
As others have said, it won't work. I'm just curious how you planning to cable it up, as neither an iPod/iPhone nor a 2007 IS have a USB jack that would fit the USB plug on that cable.
Old May 18, 2015 | 08:46 AM
pattatted4's Avatar
pattatted4
If you are using Apple products, there is an interface kit that will allow you to use all the factory controls
Quick search found this...
http://www.lextasy.com/lexus-Sl2i-adapter.htm
Hope this helps...
Old May 18, 2015 | 01:00 PM
Bichon's Avatar
Bichon
Thanks for trying to help the OP, pattatted4, but the product you found is a previous generation device from VAIS that came out when the iPhone 4 was Apple's flagship product. If he wants to invest that kind of money, he'd be better off with a current generation product like this one: http://www.vaistech.com/site/sl3b.php
Old May 18, 2015 | 09:39 PM
jjc250's Avatar
jjc250
I have a cable that has the Apple connector on one end and an usb connector on the other. But anyways I'll just stick with a regular AUX cable. Thanks everyone!
TurkEclips
Nov 8, 2023 05:13 PM
Abernoots
Jul 9, 2018 01:48 PM
Vegasaurus
CT 200h Model (2011-2017)
Mar 30, 2016 07:47 PM
madoka
IS F (2008-2014)
Mar 5, 2011 12:53 PM
