IS350 bulb install DIY with pics
Old Sep 14, 2014 | 02:43 PM
Mike285's Avatar
Mike285
Default IS350 bulb install DIY with pics
I purchased some Osram Xenerac CBI 5000k HID bulbs from The Retrofit Source. Installation was pretty easy. Overall I am very happy with the results. I would highly recommend buying from The Retrofit Source. They have great customer service and you know you are getting an authentic bulb at a good price.
Tools needed:
10mm socket
flathead screwdriver
rubber gloves
D4S bulbs
First open the good and remove all the pushpins holding the plastic covers in the engine bay. To do this just push on center of the pushpins then they should easily pop out with a screwdriver.
IMG_7683 by Tyler.Rahm285, on Flickr
Next remove the air intake. It has 2 10mm bolts.
IMG_7684 by Tyler.Rahm285, on Flickr
IMG_7685 by Tyler.Rahm285, on Flickr
Now remove the air box. Its also held on by 2 10mm bolts.
IMG_7686 by Tyler.Rahm285, on Flickr
IMG_7687 by Tyler.Rahm285, on Flickr
Loosen the hose clamp (10mm) and remove the the hose from the air box.
IMG_7688 by Tyler.Rahm285, on Flickr
Now just swing the air box out of the way. You can unplug it if you want but its not necessary.
IMG_7689 by Tyler.Rahm285, on Flickr
You should easily be able to see the cover for the bulb now. Just pull the bar back to open it up.
IMG_7691 by Tyler.Rahm285, on Flickr
Now twist the cap counterclockwise to remove it.
IMG_7692 by Tyler.Rahm285, on Flickr
pop the two springs out of the way and pull the old bulb out. Just insert the new bulb the same direction as you got the old one out. USE RUBBER GLOVES AND DONT TOUCH THE GLASS PART OF THE BULB!!
IMG_7693 by Tyler.Rahm285, on Flickr
now put everything back the way you took it apart. Next is the drivers side. Remove the tube for the windshield washer fluid. It is just a 10mm bolt and it easily pulls out.
IMG_7690 by Tyler.Rahm285, on Flickr
Now do everything the same as the other side and put everything back the same way you took it off.
Old Sep 15, 2014 | 09:00 AM
idoke1's Avatar
idoke1
Awesome diy. Keep up the good work.
Old Sep 15, 2014 | 05:12 PM
Aviator753's Avatar
Aviator753
Great. Will help me in the future
Old Sep 15, 2014 | 05:55 PM
merkin110's Avatar
merkin110
Great DIY. Just did mine today!!!
Old Sep 19, 2014 | 10:04 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Great write-up!
Old Dec 13, 2014 | 12:15 AM
dorkacho's Avatar
dorkacho
looks great! cannot wait to do mine
Old Dec 13, 2014 | 09:31 AM
Initial G's Avatar
Initial G
Thanks for sharing. Great write up!
Pics of with the new bulbs on?
Old Dec 13, 2014 | 10:44 AM
dorkacho's Avatar
dorkacho
Are there different types of sockets? The Stanley 10mm one I got doesn't fit the bolt ..
Old Dec 15, 2014 | 07:36 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
just an fyi for those interested:
Save 10% off on Osram CBI D4S HID bulbs.
Steve
trips1
RX - 1st Gen (1999-2003)
Apr 1, 2015 05:05 PM
DJSTYLE
Jul 22, 2012 01:18 PM
sunshine69
Sep 21, 2010 04:49 AM
2slow
Lighting
Jun 24, 2007 08:42 AM
sundaekim
Jan 1, 2002 04:40 AM
