'07 IS350 AC Problem
Old Aug 10, 2014 | 03:48 PM
IS350vue's Avatar
IS350vue
Default '07 IS350 AC Problem
I have a 07 Lexus Is350. My AC is off but there still air coming in. Are all lexus like that?
Old Aug 10, 2014 | 04:49 PM
mmarshall's Avatar
Welcome to CL and CAR CHAT as a new poster. Glad to have you.
You didn't mention how the other climate-controls were set, except for the A/C itself being turned off. With many (in fact, most) new cars today, compressor-operation is also linked to the windshield defogging. That means that whenever the defrost/defog mode is on, the compressor operates with it as a source of dry, dehumidified (but cold) air for the system to absorb moisture on the inside of the windshield with. Then, if the air-ducts are set into a split-level mode (say, windshield/floor or windshield/dash), some excess cold air from the compressor will also spill out of those vents onto your face or legs. This will often happen even if the A/C compressor switch itself is turned off. The defog/defrost mode, on all Lexus models and on most other new cars, will also automatically switch the intake-air duct from recirculated to fresh outside air to prevent moisture build-up. In fact, when the defog/defrost system is used, it is sometimes beneficial to add a small amount of heat with the temperature (hot/cold) control to prevent chilly air from cooling down the windshield too much and getting condensation on the outside. That will also help the defogging even more by dropping the humidity of the windshield-air as it warms.
So, if this is the case, make sure that when you are using the defrost/defog mode, the dash and floor vents are shut off if you don't want any cold air also escaping through them. There usually is no way to prevent the A/C compressor from coming on with the defrost, except that in some cases (at extremely cold temperatures outside) the system may by-pass the compressor to keep from freezing up.
We also have a specific CL thread, if you prefer, to discuss service/maintenance-related issues.
https://www.clublexus.com/forums/maintenance-11/
Old Aug 10, 2014 | 10:48 PM
Mazinger's Avatar
Mazinger
don't these cars use a variable displacement A/C compressor?
Old Aug 11, 2014 | 08:49 AM
embolism's Avatar
embolism
as long as front defrost is on, either the windshield only or windshield and footwell, the AC is on, whether the A/C button is lit up or not....
drove all winter with defrost and footwell on and got about 12.4 L / 100 km vs 11 L / 100 km the following winter after I figured it out...
Old Aug 11, 2014 | 09:21 AM
IS350vue's Avatar
IS350vue
Thumbs up
Thanks you guy for the help. I really appreciate it.
Fllexusis2
May 18, 2025 02:34 PM
ashraf1991
Mar 27, 2021 02:46 AM
evident
Jul 9, 2015 08:09 AM
bwl
Jun 28, 2012 08:57 AM
KML505
Aug 14, 2011 07:11 PM
