Driver Rear door sensor keeps going off when I make a turn or hit a bump
Old Dec 28, 2013 | 10:10 AM
GQis350's Avatar
GQis350
Default Driver Rear door sensor keeps going off when I make a turn or hit a bump
Hey guys my Driver Rear door sensor keeps going off when I make a turn or hit a bump. Ive read that putting WD-40 on the latches will help out but it still keeps going off. So frustrated with this. Any help?
Old Dec 28, 2013 | 11:58 AM
tex2670's Avatar
tex2670
Look and see if there is possibly a small dent in the inner part of the door where it strikes the sensor to determine if the door is shut. My wife closed her seatbelt in our old Honda Pilot, and this is what happened--except it wasn't around curves, it was showing the door was opened all the time. I put a felt pad (like the kind you would put under a table leg) over the spot, and that took care of it.
Old Dec 28, 2013 | 12:53 PM
quick123's Avatar
quick123
Yes, check for any damage to the striker or the latch...you might be able to adjust the striker a bit to pull the door in a bit tighter to prevent this as well.
Old Dec 28, 2013 | 01:15 PM
NYKnick101's Avatar
NYKnick101
I have the same issue. I think its a common issue with all ISx50's. I put a piece of double sided tape (the thick one) where the striker goes and it works well. Its not a great fix but it works. Im hoping that toyota puts out a recall to fix it because it seems to be common among ALL the cars
JCIS250RWD
Oct 30, 2021 01:34 PM
BennyISF
IS F (2008-2014)
Jun 27, 2018 11:57 AM
NYKnick101
Nov 8, 2013 01:32 PM
Snafu783
Jul 29, 2012 06:41 PM
hawaii5b
GS - 1st Gen (1993-1997)
Aug 24, 2005 06:08 PM
