Door Sensor - 93 G3300
Old Aug 2, 2005 | 07:18 PM
hawaii5b's Avatar
hawaii5b
Default Door Sensor - 93 G3300
I'am having issues with my driver door sensor. The door sensor light on the dash flickers on and off every time you hit a bump in the road. You get the same behavior if you lean your knee against the door. Is there away to adjust the sensor or disable it? What about replacing the sensor, has anyone attempted that, if so how much is the part? Advance thank you for any information that you can share...
Old Aug 2, 2005 | 10:06 PM
turbogs300's Avatar
turbogs300
Cool
I don't believe there is any adjustment. It can be replaced, make sure it's not just loose.
Old Aug 24, 2005 | 06:08 PM
vsd's Avatar
vsd
i had the same problem as you, i just took a piece of cardboard and taped it to the car so it was covering the sensor, problem solved.
Lzam
Mar 5, 2019 05:30 PM
BennyISF
IS F (2008-2014)
Jun 27, 2018 11:57 AM
NYKnick101
Nov 8, 2013 01:32 PM
Wahlnutz
Dec 6, 2012 09:19 AM
roblee8908
Sep 9, 2008 11:19 AM
