Side mirrors not always adjusting when in reverse..
Old 12-03-13, 05:34 AM
DKIS350
DKIS350's Avatar
Default Side mirrors not always adjusting when in reverse..
So as the title says, when I put my car in reverse, the side mirrors do not always adjust down. Not a big deal to me because honestly they adjust so low they are useless to me when they adjust down. Id say they adjust down maybe half the time. Just wondering if there's any rhyme or reason this. And there is setting to turn it off any how right?
Thanks guys
Old 12-03-13, 05:56 AM
quick123
quick123's Avatar
Yes, if you put your mirror adjustment switch to either L or R they will tilt when in reverse...if you put the switch in the middle position, it will cancel the tilt when in reverse.
Someone correct me if I have this backwards, been a while since I played with this...lol
If this is not the case with you, it is probably the motor in the mirror going bad and it will need to be replaced if you want that function.
Old 12-03-13, 06:03 AM
ICU2
ICU2's Avatar
My mirrors don't adjust down enough - I want to see the parking lines to see if I'm in the centre of a parking spot. Is there a way to adjust them without having the mirrors low during normal driving?
Old 12-03-13, 06:50 AM
DKIS350
DKIS350's Avatar
Ahhhh makes sense now! I was kind of wondering if it was something simple and of course i don't have an owners manual to refer to.
Thanks!
Old 12-03-13, 08:20 AM
Gville350
Gville350's Avatar
You are correct; I use my auto-tilting mirrors religiously when pulling backwards into my garage everyday.
Old 12-03-13, 11:33 AM
shawnxjeon
shawnxjeon's Avatar
I wish I had adjusting mirrors...
Old 12-03-13, 01:23 PM
yukky
yukky's Avatar
Lightbulb
I found a trick, which I have to perform every now and then on my car. Go outside, and with your hand, physically push the mirror to the very top position, and then to the very bottom position. This seems to help the motors to move to the correct positions. Go ahead and reset your mirrors to your saved position.
Of course, as people mentioned, your mirror switch should be set to L or R, and when you move into reverse, both your mirrors should angle downwards.
Old 12-03-13, 01:31 PM
tex2670
tex2670's Avatar
I second this. Including if you don't think your mirrors are adjusting far enough down. Just DON'T spray WD-40 in the housing...
Old 12-03-13, 02:05 PM
yukky
yukky's Avatar
https://www.clublexus.com/forums/is-...-pls-help.html
edit: that was your own experience! :O wow!
Old 12-03-13, 03:19 PM
don
don's Avatar
Mine never worked, I'll give this a try.
But it's not big deal to tilt it down when I go in reverse. I've learn to live with it for the last 3 years.
Old 12-03-13, 04:00 PM
whitebeast
whitebeast's Avatar
it wont have it cause the package you have is not luxury plus package ( AFS headlight, auto rain sensor...)
Old 12-03-13, 05:07 PM
Gville350
Gville350's Avatar
^Sports pkg also has it.
dychang174
RC - 1st Gen (2015-present)
12
03-01-17 12:26 PM
lexman52
11-27-15 05:08 PM
aleksfox
ES - 6th Gen (2013-2018)
08-18-14 09:53 PM
wushuboy
06-26-08 06:53 PM
Quick Reply: Side mirrors not always adjusting when in reverse..
