Lexus Recall
Old Oct 29, 2013 | 06:12 AM
  #121
4TehNguyen's Avatar
4TehNguyen
should get my car back today, performed the wiper blade nut and trunk release latch recall too
Old Oct 29, 2013 | 08:26 AM
  #122
my07is350's Avatar
my07is350
In my case, I got the recall done then I got the letter.
Old Oct 29, 2013 | 10:31 AM
  #123
Kumar350's Avatar
Kumar350
Been almost two weeks and no noisy starts. Cars running great no complaints.
Old Oct 31, 2013 | 05:06 AM
  #124
slickwil89's Avatar
slickwil89
Helpful feed! Good to be aware of this recall
Old Nov 2, 2013 | 09:56 AM
  #125
Soap's Avatar
Soap
Originally Posted by sy02
my IS 350 recall was done already and changed my sparkplug charged me $60 labor cost
You brought in the spark plugs right? I am scheduled to bring mine in for the recall Wednesday morning and I happen to have spark plugs I purchased from Sewell a few weeks back but haven't gotten around to installing myself. If they will do it for under $100 I may just let them do it while they have it.
Old Nov 2, 2013 | 10:19 AM
  #126
g2bme's Avatar
g2bme
Does this happen with the 250's as well? I've heard the noise during my cold start ups or at least when I drive and stop multiple times in one day. I've brought it up once before at brought it in but they couldn't duplicate the problem.
Has anyone with a 250 gotten any success in getting it fixed? I just dropped mine off for servicing and brought it to the service agents attention. He was firm on saying that the 350 is completely different from the 250 and there is no such problem with the 250's. He said he'll try to get the duplicate done but no guarantee that it'll happen. It's notated on my service history.
On a side note, I got the 2014 250 loaner and so far not impressed.
Old Nov 6, 2013 | 08:04 AM
  #127
Soap's Avatar
Soap
They wanted $130 for labor so I passed on it. Dropped the car off this morning for all 3 safety recalls only to then find out they might not even have the parts for the vvt recall. Very frustrating that I drove 45 minutes to the dealer only to find that out. Top it off with being stuck in an older is250.
Old Nov 10, 2013 | 06:26 PM
  #128
350Nva's Avatar
350Nva
Dropped mines off for the recall as well as the wiper nut and trunk release. Had a 4GS loaner for 3 days.
Old Nov 11, 2013 | 05:18 AM
  #129
shaolin's Avatar
shaolin
So I did my VVT actuator gear recall about 2-3 weeks ago and car runs the same before recall was done. Yesterday I pull my car out for a wash, while doing so I found a small puddle of oil in my garage floor. I wiped the oil off and see no signs of oil today, so I thought could it be the loaner I had was leaking? Anyway, today I jack up my car and find no sign of oil on the floor, but my bottom of car is oil wet, no signs of dripping, and it's not leaking from my normal drain plug. I check my oil level and it's exactly half way of my oil level dips stick, so for sure I have lost oil. Does anyone know if this VVT recall work will cause an oil leak? I did my oiled change 500 miles before I dropped it off for recall, now 1000 miles later problem occurs. Please help and advise....
Old Nov 11, 2013 | 06:35 AM
  #130
mike33's Avatar
mike33
It could cause a leak , the valve covers are removed, check the seal between the cover and cylinder head for signs of a leak. Obviously return car to the dealer for further inspection as well.
Old Nov 11, 2013 | 06:50 AM
  #131
5gears-IS's Avatar
5gears-IS
Great Deal Guru
Default Done
My 06 IS350 fell into the vin range to get the cam fixed. Took it to my local Lex dealer last Thursday 11.7.13 and got 3 recalls done; wiper nut, trunk release and cam. Took them less than 4 hrs to do.
I rarely had the ratlle I may have heard it maybe twice or so since buying the car a few years ago.
I am happy to say everything went well and no issues to report.
Car feels the same.
Old Nov 11, 2013 | 07:26 AM
  #132
shaolin's Avatar
shaolin
That's what I wanted to know. Thanks you!!! I will go to them and have them inspect it while i'm there. There is not signs of leakage before my recall service, if it was there they would of notified me already. I hope the leak was from them opening the valve cover, and not from not tighting up afterword. Current lost half of oil stick level of mobile 1 syn.....
Man, car never had any major issue until this service....worried......
Old Nov 11, 2013 | 07:28 AM
  #133
shaolin's Avatar
shaolin
Car feels the same.
That's not too bad. The dealer i took it to took over a day so I had loaner for 2 days. Maybe i took it in too early when they're trying to figure out how to fix the recall.... *****....
Old Nov 11, 2013 | 08:25 AM
  #134
ISFHEMS's Avatar
ISFHEMS
Just called Hennessy Lexus of Gwinnett to book my car in. The service advisor knew who I was before I gave him any of my details (caller ID?) and told me he would have to order the parts as they don't keep them in stock.
He said he will call once the parts are in and that he will also get the wiper nut and trunk recalls done while it's in too and that a courtesy car would be available as it would be in all day.
I bought my car from this dealership a year ago and have had an overall positive experience so far!
Just wanted to give some praise!
Old Nov 11, 2013 | 09:10 AM
  #135
shaolin's Avatar
shaolin
That's cool. Not all my experience was bad so yes i'll give to some service The shop foreman called me this morning and told me to bring the car back today to relook. If I had leak before the recall wprl they would've let me know before hand, and very possible this leak was caused by the recall done. Will see what they find out today and hopefully no $$ out of my pocket and most importantly they can fix the problem.
