2012 OEM ballast problem?
Old Jul 7, 2013 | 01:18 PM
DFig619's Avatar
DFig619
Default 2012 OEM ballast problem?
Did a search and couldn't find a definit answer for a 2012 model
So on my 2012 is250 I did a 6k d4s bulb swap (DDM tuning) as well as a 6k kit for the fogs. When on, My driver side headlight flickers And shuts off, thinking it was the bulb I swapped them, still the driver side flickers then shuts off. Now im assuming its the ballast "/ my Question is, could there be any way it isnt the ballast cause I know that's a pain in the a** to swap. Car is less then 10k miles and we are the first owners
I checked the bulbs they seem ok vs. the slight haze in the round ball part of the bulb (but then again swapping and it still being a problem on the driver side)
Any guidance or help is appreciated!
Old Jul 7, 2013 | 02:18 PM
chi123's Avatar
chi123
I would just put the stock bulbs back in if you have them and see what happens. If it still happens, bring it to the dealer cause if it's a bad ballast, you get a new headlight since you're under warranty.
Old Jul 7, 2013 | 02:54 PM
DFig619's Avatar
DFig619
Just installed stock bulbs, seems to work fine, could be a bad DDM tuning bulb, but it's strange that I even swapped them. Not sure if I want to go aftermarket now "/
starstreak
Oct 3, 2018 01:45 AM
Gerod77
May 6, 2014 12:27 PM
Jaybeck860
IS - 1st Gen (2001-2005)
Jan 27, 2014 11:08 PM
milellie11
Jun 28, 2011 03:21 PM
UNCGS06
Oct 11, 2010 10:19 AM
