OEM ballast replacement?????
Old May 1, 2013 | 08:03 AM
jay-b's Avatar
jay-b
Default OEM ballast replacement?????
Do i really need to remove the headlights to replace the driver side ballast? Looks like mite be shot, the light is dim (looks like a halogen bulb) and wouldnt turn on at times.
Old May 1, 2013 | 08:25 AM
lysis250's Avatar
lysis250
Yes you really have to remove the headlight.
Old May 1, 2013 | 08:33 AM
jay-b's Avatar
jay-b
is the ballast beneath or in the housing of the headlight?
Old May 1, 2013 | 08:40 AM
bob4256's Avatar
bob4256
Its underneath the headlight
Old May 1, 2013 | 10:01 PM
AZGHOST's Avatar
AZGHOST
It's a PITA to get out, but there's a way to replace your ballast without cutting up or messing up your headlights... There's a video on how to do it... I will see if I can find it and post it
Old Feb 12, 2014 | 01:53 PM
chingy604's Avatar
chingy604
Where you able to find the video?
I bought the ballasts. Just going through the easiest option to remove and install it.
Old Feb 12, 2014 | 03:52 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
What year is your car?
Jeff
Old Feb 14, 2014 | 04:07 PM
chingy604's Avatar
chingy604
2006 is350
Old Feb 26, 2014 | 09:26 AM
ramon357's Avatar
ramon357
Anyone know a good place to get the ballast online?
TIA!
Old Feb 26, 2014 | 09:35 AM
rogers2's Avatar
rogers2
Veteran: Navy
I just went thru this same process 3 weeks ago. I actually purchase a ballast off ebay. The custom led light shop only replace my prong since I told them the aftermarket bulb fried it.
Word of advice to everyone don't put those cheap led lights in your car. A 12 dollar bulb cost me over 450 dollars in the end.
Old Feb 26, 2014 | 11:33 AM
AZGHOST's Avatar
AZGHOST
Well said!
Old Feb 27, 2014 | 05:51 AM
Armymedic's Avatar
Armymedic
I just replaced mine last week and it really isn't that bad to do. You have to take the bumper off then take the headlight out. Like previously stated you can remove the ballast wires without taking apart the headlight. At the end of the wire is a silver shield that has to be removed, than take apart the black casing and pull the connectors out.
Old Mar 16, 2014 | 06:08 PM
nippiexfam's Avatar
nippiexfam
What LED bulb was it? and which bulb? city? parking? DRL?
kevin3344
Nov 4, 2018 11:31 AM
Toxicxk23
Aug 8, 2013 07:46 AM
ApokC
Feb 8, 2012 09:17 PM
bklynjoker
May 12, 2010 12:27 PM
FLIPPU
Lighting
Sep 17, 2005 02:15 PM
