Quick Question - Australia.
Old Mar 25, 2013 | 11:01 PM
Fanel's Avatar
Fanel
Default Quick Question - Australia.
Hey don't really post on here, mainly just come to see what everyone is doing.
Curious as to how some of you get so low without scraping on your front. I have done the following and I still scrape going over slight bumps in the road.
I am currently lowered on bc coilovers, running Vossen CV2's with 225/35 on the front. Installed is the SPC Ball joints and running -1.5 Camber. Guards have been rolled as well. The Front dampening is as hard as it can be. Also have the Figs Engineering bushes.
Have taken the fender liners out for now and have shaved the bumper tabs.
Is there anything else I can be doing as not to scrape. Thinking I might drop the tyre down to 225/30.
Any help would be appreciated.
Old Mar 26, 2013 | 06:00 PM
Gville350's Avatar
Gville350
Not all roads are created equal. Hell, some areas even in the US you cannot go too low unless you want to lose that bumper.
Old Mar 26, 2013 | 07:30 PM
ArtG's Avatar
ArtG
Not afraid of defect notice??
Old Mar 26, 2013 | 07:50 PM
MR2QIK's Avatar
MR2QIK
Maybe post pictures of how your ride currently sits, what scenarios is rubs. Aussie roads are pretty bad compared to some areas of the US etc.
Wheel fitment is a fine art & drivers have different standard. Many don't mind some rubbing, whereas others panic when they hear a small/minor one with a full load of passengers.
Old Mar 26, 2013 | 08:23 PM
Fanel's Avatar
Fanel
Yeah I have noticed that, even within Australia.
Haven't had any problems yet, if I do I will deal with it then.
Will take some photos this afternoon and go from there. It's mainly on highway driving, railway lines, divets in the road etc.
I don't mind the rubbing, I can't go up certain driveways without scraping on lock.
Old Mar 27, 2013 | 09:34 AM
Sffd103's Avatar
Sffd103
Fire Slayer
I'm using 225/30/20...that might be it.
Old Mar 27, 2013 | 09:52 AM
Vroomin350's Avatar
Vroomin350
225/30 is your best bet. Post pics.
Old Apr 28, 2013 | 08:24 PM
Fanel's Avatar
Fanel
So I went with the 225/30 only to pop a bead and tear up the rim a bit
Was running 45 PSI, what should I be running, wil ltake photos this after noon and post.
Been so busy with work past few weeks.
Old Apr 28, 2013 | 10:07 PM
509IS350's Avatar
509IS350
Wow. Yeah 225/30 is your best bet for not rubbing. Im running Hankook V12s at 40 psi. Sorry to hear that you pop the bead.
Old Apr 30, 2013 | 11:56 PM
Fanel's Avatar
Fanel
So what other tyres besides the Hankook V12's that people run? When I was running 235/35 I had Achillies and no problems. Also what other sizes can we run, ie 235/30??
Had mine rebeaded, will see how we go
Old May 1, 2013 | 12:53 AM
faisal11ir's Avatar
faisal11ir
Michelin PSS is the best.
Old May 1, 2013 | 02:21 AM
509IS350's Avatar
509IS350
It was probably the bad bead. Another tire I might try next time are BFG KDWs. You can run 235/30, since Im 15mm running spacers. I chose to run a smaller width tire to comp for it. Heres what it looks like. 20x9+23 on 225/30 in the front
Old May 1, 2013 | 05:20 AM
iRyan's Avatar
iRyan
225/30 would be perfect for more room to go lower...if you removed your fenderliner and did your tabs you can dame near slammmmm it...if you r not running spacers... but with liner installed you can go a total of 2 inches i thing without rubbing... im running 225/30 with 39 psi 40 at maxx
Old May 2, 2013 | 02:19 AM
Fanel's Avatar
Fanel
Firstly, car looks great!! So you think 235/30 is possible?
My fenders are removed currently but will put em back on soon, tabs also done. So no more than 40 psi max? Can't go to low as our roads etc are not as good as you guys in the states....
Had my tyre rebeaded and seems like it has sort of bubbled on one side, could this be the problem of the bead popping/leak?
aznbo187
CT 200h Model (2011-2017)
Jun 9, 2016 04:39 PM
BoyOhBoy
Jun 19, 2014 08:10 AM
vbb
IS F (2008-2014)
Jul 17, 2012 06:59 AM
lkapimp216
VIP Style
Oct 1, 2010 03:33 AM
