Wheel problem
Old Oct 20, 2012 | 07:13 AM
305iskid's Avatar
305iskid
Default Wheel problem
Okay, i purchased some OEM's off a TSX, The Hub on them is suppose to be 64.1, on the Lexus it should be 60.1, i didnt know this till i bought them.
Ok well the back wheels fit just fine, no issue at all, the fronts however, dont sit flat on the hub.. I did change the front rotors to slotted ones that i purchased, but they should be OEM size, if the OEM hub is 60, and the wheels are 64, why wont the wheels fit on and not sit flat ? Im gonna mesaure the front hub later today to verify that for whatever reason that the rotors didnt change the size since they are not OEM but that wouldnt make sense to me.
If the numbers are correct, the wheel should fit just fine but have play in the center
Old Oct 20, 2012 | 07:32 AM
RDIS250AWD's Avatar
RDIS250AWD
why'd you get TSX wheels though?
Old Oct 20, 2012 | 07:35 AM
305iskid's Avatar
305iskid
Got them cheap and they look good, just needed a quick replacement
Old Oct 20, 2012 | 07:55 AM
reyoasian's Avatar
reyoasian
hubrings maybe?
Old Oct 20, 2012 | 08:19 AM
rookieIS's Avatar
rookieIS
If the hub size is bigger then it should still fit.
Did you check if the wheel clear your brakes and camber arms?
Old Oct 20, 2012 | 08:51 AM
chase350's Avatar
chase350
Tsx wheels on a Lexus LOL!!!
Old Oct 20, 2012 | 10:02 AM
Vroomin350's Avatar
Vroomin350
their actually not bad looking wheels. Make sure there are no hubrings already in them. Like rookie said make sure it clears your brakes and camber arms.
Old Oct 20, 2012 | 12:03 PM
rookieIS's Avatar
rookieIS
agreed, i wouldnt mind them as beater wheels
Old Oct 21, 2012 | 05:17 AM
305iskid's Avatar
305iskid
It didnt look like they were hitting on anything but im going to double check monday. I got the wheels cause i had to get rid of my Vossens and im going on vacation in December and couldnt drop 2k on new wheels so these will have to do until i get back
Old Oct 22, 2012 | 01:23 PM
305iskid's Avatar
305iskid
So the hub on the front is 70mm... what gives ?
IS250Z
Performance
Mar 8, 2019 05:51 AM
PetesLS400
Dec 10, 2013 12:28 PM
rayac88
Sep 5, 2012 12:03 AM
stephencd1
Aug 23, 2009 01:49 PM
madoka
Jun 19, 2008 06:32 PM
