Should I be worrying?
Old Jun 19, 2012 | 04:07 PM
dyongg's Avatar
dyongg
Default Should I be worrying?
Today I decided to lower my front a little bit more because I recently fixed the problem with the tire rubbing on the bumper tab (I had to raise it for a little while because the rubbing was way too excessive and I didn't have time to fix it).
I currently have KW V3's on my car and everything on my driver's side went smoothly. When I went to the passenger side, I lowering but it started getting extremely stiff even with it unlocked.
I didn't think much of it but when I went to lock it, it wouldn't go in as far as it usually would and it was a lot harder to screw in.
My question is, should I be worrying about this? Is there anything wrong with it or is it perfectly fine?
Old Jun 19, 2012 | 04:22 PM
Gville350's Avatar
Gville350
What part exactly was getting "stiff"? The threaded body, a locking collar, or the dampening adjuster?
Old Jun 19, 2012 | 04:58 PM
dyongg's Avatar
dyongg
After I unlock it with the Allen Key and try to lower it, it's super stiff.
I think that's the locking collar?
Old Jun 19, 2012 | 06:34 PM
SCWB's Avatar
SCWB
You might have got the locking collar jammed because of road sand and debris.
Before adjusting the collar, have you blown the threded area around (above and below) the collar with compressed air?
Also cleaner spray and brush should be used to get the debris out as much as possible.
Old Jun 19, 2012 | 09:46 PM
dyongg's Avatar
dyongg
Oh I see. I didn't realize the dirt and stuff would make that much of a difference!
I'll try to clean it out tomorrow! Thanks SCWB and Gville!
Old Jun 20, 2012 | 03:37 PM
Gville350's Avatar
Gville350
Blast the threaded body with WD-40 or PB Blaster. That'll get'r loosened up!
jdmgs300
GS - 1st Gen (1993-1997)
Jan 29, 2010 06:30 AM
daandman
Mar 19, 2009 06:51 AM
-Future-
Jul 14, 2008 06:10 AM
silkiechic
Dec 14, 2005 02:58 PM
Taka
Sep 5, 2003 03:30 PM
