sc's acting up, electrical issue?
Old Dec 13, 2005 | 03:39 PM
silkiechic's Avatar
silkiechic
Default sc's acting up, electrical issue?
Hello, so far I haven't found what my problem is. Maybe this belongs in the maintence section?
Once in a while, like when its hot outside, the passenger door doesn't lock when you lock the car with the keys or manually from the drivers side, not too much of a problem...
Now, I've noticed, like maybe once a month or so, maybe twice or so. The car's head lights dim when breaking or signaling... sometimes the radio will go out for a bit when signling. This isn't every day or every time I start the car. Just once in a while very sporadically. I checked the battery and its' fine. Could the wireing need replacing or something? Any ideas? Thanks
It's a 93 sc300 with 120k miles.
Old Dec 13, 2005 | 03:40 PM
np20412's Avatar
np20412
Usually when electrical systems suffer from braking, it is the cause of a bad grounding somewhere.
Old Dec 14, 2005 | 01:01 PM
mikeloc24's Avatar
mikeloc24
What's up stranger??? Where've you been? Playing with chickens probably
I had this same issue and I bought a new battery and had all my grounds checked and tightened and this solved the problem. Do a search for "ghosts" or "electrical ghosts" and read what I was talking about
Fix it before it gets worse. You can get a good inexpensive battery from Walmart if you need to.
Old Dec 14, 2005 | 02:58 PM
silkiechic's Avatar
silkiechic
Thanks, I'll go check the grounding on the car.
To what I've been up to. Just alot of school work and just a little bit of the chickens. Today was my last final so life is good... I hope... hehe.
heynamesmi
Jun 20, 2020 12:48 PM
ezduzit
RX - 1st Gen (1999-2003)
Jul 11, 2016 11:08 AM
wht97
Feb 3, 2013 08:43 PM
Btmnk21
RX - 3rd Gen (2010-2015)
Jun 6, 2012 03:05 PM
LEXISM
Oct 25, 2004 11:09 PM
