Another TRC question
I have an 07 IS350 and after holding the traction control button down for 5 sec. the "trac off" and "Vsc off" lights come on, but the car will still not break the rear tires loose from a dead stop. Somehow feels like it is still engaged...
Other than this, the car runs great. Any idea's?
Also, does anyone know if the car disables the A/C at WOT?
You could try brake torquing to around 3k RPM's and then dropping the hammer. Almost guaranteed to break the wheels loose unless you're on a prepped track with slicks.
The AC compressor is variable displacement, so it's pretty much off at WOT (though the technical explanation is a bit more complex)... see here for more info:
https://www.clublexus.com/forums/3415277-post2.html
and what tires are you on? Mine don't break loose when floored with the Hankook V12s, but they did with the crappy Turanzas the car came with.
I actually broke them loose a while ago, but I was on different pavement and had the power button thingy on. Pretty sure it had more to do with the road texture than anything. Before, I was on a tar and chip road and I guess it was a bit rough and sticky.
Anyhow, she's running great, so I'm not gonna complain.
As for the A/C, on my wife's caddy it would shut down the a/c at WOT. Just wondering if this Lexus would do the same so I would not have to turn it off when I wanted full power.
Thanks for the replies.
It should be disabled until you turn off the car or hit the hit button again.
