H.I.D lighting pattern on road not correct?
Old May 8, 2012 | 02:39 AM
lex28's Avatar
lex28
Default H.I.D lighting pattern on road not correct?
Hello all..
ive recently purchased some H.I.D lights (6k) but pattern on the road is not correct..like traingle shapes on the road and a few 'black spots' where no lights is visible on the road too..??
do i need to upgrade projectors? or should it be normal plug and play and off you go??
im quite new to the car, so bear with my lack of knowledge..
Old May 8, 2012 | 09:46 AM
SILVRLININ's Avatar
SILVRLININ
Did you attempt to adjust the vertical and horizontal height? If not properly adjusted, your beam pattern will become out of whack.
Old May 8, 2012 | 09:52 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
I'd think that maybe the bulb is the wrong type and/or it is sitting in the headlight slightly off. Putting HID kit into a halogen projector isn't the best beam, but you shouldn't have any weird shapes or odd dark spots.
Jeff
Old May 8, 2012 | 10:13 AM
03pcoupe's Avatar
03pcoupe
Yeah, what the above two posters said... Make sure it was installed/centered correctly in the bulb holder.
Old May 8, 2012 | 10:20 AM
langjaykev's Avatar
langjaykev
yeah.. i tried fixing my beam pattern for a year now, and i just gave up.
right side goes / ~ (not sure how else i can show it LOL)
Old May 8, 2012 | 10:53 AM
ramainli's Avatar
ramainli
Take a pic.
Old May 9, 2012 | 02:31 AM
lex28's Avatar
lex28
Thanks guys....
ive checked one of the bulbs and it wasnt sitting perfect in the slot, so now adjusted and looks ok...will test when the sun goes down...
Old May 9, 2012 | 06:53 PM
my1s250's Avatar
my1s250
the return wire on the bulb supposed to be facing the rear you prolly have it facing the wrong way.....happened to me twice =)
Old May 9, 2012 | 07:09 PM
langjaykev's Avatar
langjaykev
Best one i have, hard to see what I am talking about. But for some the rod is there.. I made sure the rod is facing the rear as well.
Old May 9, 2012 | 07:19 PM
my1s250's Avatar
my1s250
rear but at an angle toward the bottom ..you can tell by the square notch on the bulb and on the headlight toward the bottom.....don't know why they make it so hard just to change out bulb LoL...just change mine to 6k last week took me almost 2 hour just twisting and turning the bulb around and around
TEAMxREX
RX - 1st Gen (1999-2003)
Jul 18, 2012 04:27 PM
huerdo623
Lighting
Jul 28, 2007 11:25 PM
GammaLex
Lighting
14
Jun 25, 2003 06:05 PM
looknow12
GX - 1st Gen (2003-2009)
22
Jan 31, 2003 11:57 AM
wolfy187
May 6, 2001 03:58 PM
