Door help!!!
Old Apr 13, 2012 | 06:42 AM
M88JCP's Avatar
M88JCP
Unhappy Door help!!!
Hi everyone
Hopefully somebody can help me,
I'm having some real problems with my drivers door, as my car is a 2007 model my warrenty doesn't cover adjustments, interior trim etc so won't help me with this.
My problems are:
- Every time I go over any rough ground my door sounds like it's moving around in the aperture. Its like the door isn't properly shut and is moving. I saw on here a while back a trick with electric tape wrapped round the door catch, I've done this and it did work for a little while. Its now come back even worse than before, and changing or adding to the electric tape doesn't help.
- When i'm driving my car in rain, I can hear water moving around before my right ear. I think it's is coming from the back of the drivers door seals.
- The very top of my drivers door isn't flush with the top of the rear drivers door, but the middle and bottom is.
My cars not been broken into, not had any accident damage and ive lubricated all the seals etc a number of times. But nothing helps anymore
Has anybody got any ideas on what I can do to rectify this, or atleast get rid of the noise?
Thanks
M88JCP
Old Apr 13, 2012 | 08:48 AM
ibidu1's Avatar
ibidu1
You can adjust the door stricker a tad inward, that will make the door close tighter to the car.
Old Apr 14, 2012 | 07:00 AM
M88JCP's Avatar
M88JCP
Sorry, what is the door stricker?
Thanks
Old Apr 14, 2012 | 09:38 PM
ibidu1's Avatar
ibidu1
Thanks
Door striker is a pin bolted to the car, the doors lock/latch locked into it when you close the door. If you loosen the striker a little bit and tap it inward the door will close tighter to the body of the car. Any body shop can fix this and its very easy. Takes 5 min
Old Apr 15, 2012 | 11:39 AM
M88JCP's Avatar
M88JCP
Brilliant, thankyou
Old Apr 15, 2012 | 01:06 PM
JohnLX300's Avatar
JohnLX300
I hear that same noise in the rain as well, let us know if it works!
Old May 23, 2013 | 07:40 AM
jfass958's Avatar
jfass958
10th Gear
Did this work out? I'm having the same problem.
Old May 23, 2013 | 07:51 PM
Gville350's Avatar
Gville350
So you've been the only owner of this 2IS and are 100% sure it was not in an accident?
soupcxan
CT 200h Model (2011-2017)
Sep 24, 2017 02:10 PM
aristoboyy
GS - 1st Gen (1993-1997)
Jan 22, 2015 01:22 PM
bagyo
Jun 28, 2013 03:29 PM
vipman806
Jul 17, 2010 12:31 AM
92Es300 5sPd
Feb 16, 2003 06:24 PM
