100k
Feb 4, 2012 | 12:43 PM
100k
about to hit 100k miles on my 2006 IS350...most of it is highway miles. but the car is running great...never had any engine problems except for the recalls...any suggestions on what absolutly needs to be done..
I know the manuel says to change the radiator fluid but do i need to if ive never had to mess with my engine before???
your suggestions would be greatly appreciated
Feb 4, 2012 | 01:27 PM
my suggestion is to follow the suggested maintenance schedule.
Feb 4, 2012 | 02:54 PM
I would follow what the manual says, you might also want to do the spark plugs if they haven't been done (every 60K) and the brake fluid (every 30K).
Feb 4, 2012 | 04:03 PM
Have you had your water pump replaced? I thought the coolant was a "lifetime fluid"?
Feb 4, 2012 | 04:32 PM
Quote:
Originally Posted by
Gville350
nope..never needed to...the only thing changed was the fuel rail
Feb 4, 2012 | 04:42 PM
Gville350
Coolant gets replaced first time at 100k miles and every 50k miles after that.
Jeff
Feb 4, 2012 | 04:46 PM
Jeff Lange
Jeff
I was always told that if its not giving u any problems then there no need to change it...any thoughts..and if i do change it how much does that cost
Feb 4, 2012 | 04:56 PM
chris83
According to the manual at 100k you need to:
Replace engine oil
Replace engine coolant
Replace Cabin Filter
Re-Torque axle shaft flange bolts
Rotate tires (If applicable)
Misc. inspections
Cost depends on where you go.....dealership will for sure be more expensive, independent shop will save you some $$.
evident
Dec 2, 2025 08:39 AM
Zsikd
Jun 19, 2019 07:24 AM
iH8RICERZ
IS F (2008-2014)
Jul 25, 2017 12:46 PM
hrmhrm
Hybrid Technology
Jan 13, 2012 08:37 AM
e-man
Maintenance
13
Dec 17, 2008 06:00 AM
100k ,
2006 ,
engine ,
is250 ,
is300 ,
is350 ,
lexus ,
maintenance ,
oil ,
pump ,
service ,
water
