Lighter port + Ipod
Old Jan 3, 2012 | 07:27 AM
Yuri101's Avatar
Yuri101
Default Lighter port + Ipod
Alright so when i use my aux cable to play through my iPod everything sounds fine, but when i also use the lighter port to charge it at the same time i get weird static/whiny noises? Anyone heard of a problem like this and what is the best way to fix it? I'm probably going to take it to the dealership, but rather not if i can fix it myself. 2009 lexus is250 awd
Old Jan 3, 2012 | 07:44 AM
mier's Avatar
mier
That is normal, I have same noises. Just dont charge and listen at the same time that is my solution!
Old Jan 3, 2012 | 07:55 AM
Yuri101's Avatar
Yuri101
Did you try to get it fixed? it's really annoying and i want to do both so i don't need to keep charging my ipod at home.
Old Jan 3, 2012 | 08:00 AM
c-low's Avatar
c-low
grom
its the fix
Old Jan 3, 2012 | 08:20 AM
Daisy81's Avatar
Daisy81
Does the 2009 model have the usb connection where you can use the apple usb to I device cable?
Old Jan 3, 2012 | 09:01 AM
BernieIS's Avatar
BernieIS
This is not a problem that can be fixed. This is the amplifier magnifing the interference from the power source(cigarette lighter adapter) and it comes through the speakers as static. You will look like a complete fool if you take it to the dealer and ask them to fix this.
Old Jan 3, 2012 | 09:13 AM
Kurtz's Avatar
Kurtz
That's completely wrong... not only will they fix it, there's a TSIB detailing the fix for exactly this issue.
The "problem" is a ground loop. They add a group loop filter to the AUX port in the center console, and voila, problem is gone.
All free under warranty.
If you're OUT of warranty then you can do it yourself following the TSIB directions (though the part will likely be a lot cheaper at radio shack than the lexus part that does the same thing)
Here's one of the many threads on the topic:
https://www.clublexus.com/forums/is-...-released.html
it goes back to 2007... includes a copy of the TSIB
Note that it has been updated since then to include newer models, but the basic process remains the same.
Old Jan 3, 2012 | 09:35 AM
516IS's Avatar
516IS
^^^ Good to know, thanks Kurt!
Old Jan 3, 2012 | 09:53 AM
J3ffrey's Avatar
J3ffrey
How does a forum moderator not know this- it's only all over the place !!?? Holy cow as I was reading that post I was cringing!!
Old Jan 11, 2012 | 10:24 AM
Yuri101's Avatar
Yuri101
Thank you for the replies I will read more about it and look at the TSIB
nope only has a aux port in the arm rest. Wish it had a usb port.
Old Jan 11, 2012 | 03:16 PM
Kurtz's Avatar
Kurtz
09 relocates the ports slightly so it's easier to use longer plugs compared to 06-08... it's 2010 and up that get a USB port
Dr. Jekyll
Apr 21, 2022 07:08 PM
jimmymagic
RX - 3rd Gen (2010-2015)
Sep 30, 2015 07:40 AM
chileboy
25
Nov 14, 2013 04:02 PM
richard203
May 11, 2013 03:32 AM
RTIS250
Jun 14, 2010 01:06 PM
