Window switch blinks help pls
Old Jan 2, 2012 | 07:52 PM
Crzyxcrys's Avatar
Crzyxcrys
Default Window switch blinks help pls
Hi the windows on the passenger side cannot be rolled up or down from drivers side
However they can be rolled down from the respective switch ( passenger front n rear roll up n down with their switches)
The switches blink though! Blown use?
Where is the fuse box for the windows?
Old Jan 2, 2012 | 07:58 PM
KillaIS250's Avatar
KillaIS250
This happens when you disconnect the battery.
You need to go to each door and hold the switch on each one till it goes all the way down, and then hold it till it goes all the way up again. Do not use the automatic up/down, hold each one all the way down and then all the way up. Then the lights should stop flashing and the drivers controls should work again
Old Jan 2, 2012 | 09:03 PM
Jzsicklexi's Avatar
Jzsicklexi
This has to be the most popular post!! Yes, what killa said is correct. Takes 2 mins and you're good.
Old Jan 2, 2012 | 11:15 PM
Crzyxcrys's Avatar
Crzyxcrys
Thanks guys
dany916
IS C
Jul 8, 2025 10:38 PM
mpatton
Aug 16, 2016 08:07 AM
wickedfn4u
Dec 5, 2007 10:36 AM
bmoon_007
GS - 1st Gen (1993-1997)
Aug 24, 2007 11:34 PM
forksports
Aug 24, 2007 06:46 PM
