mis-aligned panels :(
Old Nov 26, 2011 | 04:37 PM
Kingdavid's Avatar
Kingdavid
Exclamation mis-aligned panels :(
Hey guys,
I discovered today, after driving over a f***ing CHASM of a poithole that the front drivers side panel has lifted where it meets and runs along the headlight housing which results in the narrow part that terminates into the from bumper panel is mis-aligned enough to where I have to pull the hood release to make it flush with the hood.
It's not bad enough that its noticable from a distance or even up close if you're not looking for it but I know it's there and it's driving me crazy. I can put up some pics if you guys want but even in the ones I took it's hard to notice at all.
So I'm wondering if there's anything I can do? Has this happened to anyone before? Ideas on a fix? I don't think It's a bent frame or anything, I didn't hit THAT hard but it was a pretty jarring bump. Any help out there?
Old Nov 26, 2011 | 05:24 PM
istundra's Avatar
istundra
i would imagine your wheel to be bent for this kinda pot hole. are they OK?
Old Nov 26, 2011 | 06:35 PM
SCWB's Avatar
SCWB
If you hit a pothole hard enough to cause the frame damage ,other parts such as wheel, control arm and shock absorber should have been damaged before it reached the frame.
Have you checked your wheel, control arm and shock after the incident?
Old Nov 26, 2011 | 08:48 PM
chikoo's Avatar
chikoo
I had an econobox with same damage going over a pothole. No damage to the wheel though.
Old Nov 27, 2011 | 11:15 AM
Kingdavid's Avatar
Kingdavid
After checking my suspension, wheels, etc. the only other damage seems to be a small chip in the wheel which I'm not entirely certain wasn't already there. That's the reason I'm not sure what to do about this. If the damage was to the suspension or frame I'd know what to do for a fix. But this just seems like the body panel somehow came up on its own. Downright confusing if you ask me.
Old Nov 27, 2011 | 01:40 PM
Gville350's Avatar
Gville350
Before its too late get a picture of the pothole. If it is part of a roadway that the NCDOT is supposed to maintain you might have a case. Lawyer up?!
Old Nov 27, 2011 | 02:42 PM
rookieIS's Avatar
rookieIS
pictures of the damage would help.
Old Nov 27, 2011 | 05:35 PM
MIA_LEX's Avatar
MIA_LEX
there are rubber stoppers in your hood. Raise one up on the side to make it more flush.. all i can come up with from what i think you described
Old Nov 27, 2011 | 06:58 PM
SCWB's Avatar
SCWB
Ok, if i get you right, then it might not be a frame damage.
May be the underside of your bumper was hit/pushed by the pothole then it was pushed against the fender?
Old Dec 3, 2011 | 07:59 PM
Kingdavid's Avatar
Kingdavid
Ok so here's a pic of the panels, it's not that obvious when you just LOOk at the car but if you get close...
and, to make matters worse, I was checking out my wheels again today and I found a crack...after gently pulling at the edge of the crack....
So now I'm super bummed. any ideas on the panel? and, more importantly anyone have a rim they wanna sell?
ROSCOGX470
GX - 1st Gen (2003-2009)
Jul 13, 2021 02:51 PM
DonMolina
Aug 4, 2014 04:30 AM
Opachu
May 22, 2013 09:49 AM
Jace_91
Mar 22, 2011 09:30 PM
topdog849
Jan 11, 2008 09:17 PM
