vsc light
Old Nov 16, 2011 | 04:44 PM
tame's Avatar
tame
Unhappy vsc light
hey, i just start my car and my vsc light came on, do you guys know what that means.. its 2006 is 250
awd.thanks in advance
Old Nov 16, 2011 | 04:49 PM
WIZARD1325's Avatar
WIZARD1325
Means your slippin regain control
Kurtz's Avatar
Kurtz
It can mean literally anything- it comes on anytime there's a check engine light.
Check your gas cap, see if it's tight. If it isn't, that's it.
If that's not it you'll need to get the codes pulled (autozone type places usually do this free)
Old Nov 16, 2011 | 07:29 PM
tame's Avatar
tame
thanks alot guys
Old Nov 17, 2011 | 01:43 PM
PMINTY's Avatar
PMINTY
Happened twice to me in October... it was both oxygen sensor failed within 3 days of one another.
Old Nov 17, 2011 | 04:04 PM
n8236's Avatar
n8236
I had the same issue and it was an O2 sensor issue. It's not covered under warranty, get it fixed outside of Lexus dealership.
Old Nov 17, 2011 | 06:22 PM
Bichon's Avatar
Bichon
There are two front and two rear sensors. Which ones failed?
Old Nov 17, 2011 | 09:43 PM
98023IS250's Avatar
98023IS250
I just am not impressed with the Lexus. Yesterday, I am sitting at the light and the car starts shuddering & VSC warning light comes on. I had the injectors cleaned under warranty about 5k ago and of course now the car is not under warranty. I wound up pulling over and shutting the car down. Turned it back on and the light went off. I am still on eggshells as I drive. I put in some STP injector cleaner and so far, it is OK.
Just dreading the warning light coming on again.
Old Nov 18, 2011 | 05:46 AM
Kurtz's Avatar
Kurtz
Sounds like the carbon build up issue, there's a very very very long thread on it, including the most current solution from Lexus.
Old Nov 18, 2011 | 08:05 AM
98023IS250's Avatar
98023IS250
It probably is and as stated, the carbon cleanup was done less than 10k ago. There is just something wrong that our cars continue throw up codes and have these issues.
Old Nov 18, 2011 | 09:22 AM
Kurtz's Avatar
Kurtz
You said your injectors were cleaned... this has nothing to do with the carbon issue.
The part that has the carbon buildup never gets touched by fuel... (which is why it happens to the 250s only- on 350s the port injectors flush that area with fuel and keep it clean)
lexman52
Sep 26, 2016 09:06 PM
chico55
May 15, 2014 08:24 PM
daddio054
Nov 18, 2013 08:25 AM
So Philly1
Jul 3, 2012 09:06 PM
Jrud87
Dec 29, 2011 10:38 AM
