Windshield molding question
Old Sep 30, 2011 | 04:09 PM
Soap's Avatar
Soap
Default Windshield molding question
Guys,
I just recently purchased a 2008 IS350 from California and had it shipped to me in Texas. I realized after driving it I had wind noise coming from the top of the windshield. After inspecting it I see that the windshield is not original and whoever replaced it did not put the top molding piece back on. WTF??? I was just going to purchase the molding from sewell (under $20) and put it on myself. Does anyone know if this piece is is just pressed in place. I assume it is adhesive backed? Thanks
Old Sep 30, 2011 | 05:35 PM
anthrax144's Avatar
anthrax144
What top molding? I don't have one either. I don't see it's an option to purchase from Sewell.
http://is.sewellparts.com/images/oem...000/751552.jpg
Old Sep 30, 2011 | 06:05 PM
Soap's Avatar
Soap
http://is.sewellparts.com/oem-catalo...S350-2008.html
7553353040 MOULDING, WINDSHIELD, OUTSIDE
Old Sep 30, 2011 | 06:33 PM
Soap's Avatar
Soap
The more I look at pictures online I don't see any moulding. I am not sure what this part is I see on sewell website. Ugghh...
Old Sep 30, 2011 | 06:45 PM
anthony206's Avatar
anthony206
Smile Same situation
I have the same problem with my Lexi too. After buying the car. I didn't realize both of my windshield molding is crack. You need part number 77551 ( left ) and 77552 for right side plus outer clip .
Just order mine from Sewell Lexus with club member discount
Old Oct 1, 2011 | 08:40 AM
Soap's Avatar
Soap
Okay, I did check my side moulding and of course it is all cracked and deteriorated. I just dropped it off at the dealer for the low dust pad TSB and asked them to check into the mouldings. I am not sure if they will balk since the windshield is not original. I need to search for the TSB because I don't think it says anything about not being covered if it isn't the original windshield.
Old Oct 1, 2011 | 11:33 AM
Soap's Avatar
Soap
Just got a call from the dealer, they replaced my brake pads with the low dust units per the TSB and they claimed they didn't hear any wind noise but agreed to replace both side moldings under warranty due to cracking. They don't think that would cause wind noise but I disagree.
Old Oct 1, 2011 | 11:56 AM
B16da9's Avatar
B16da9
If your car is still under warranty take it to the dealer and they should replace it under warranty. My sister just bought an 08 IS250 and she had these same items replaced under warranty as they were also cracking.
Old Oct 3, 2011 | 08:09 AM
brociouz's Avatar
brociouz
There is no TSIB for the cracked side windshield moldings, but it should be covered if you're still under the original warranty. For those outside their warranty period, if you complain they'll often offer to comp the parts, but you still pay labor.
I have to say I agree with the dealer here - I doubt that cracks in your side windhsield moldings would cause much noise.
Old Oct 3, 2011 | 09:34 AM
flektone's Avatar
flektone
Guys,
are you talking about part#7533G? The top upper thin molding strip? I dont if that can be replaced without removing the entire windshield. Mine is all beat up and I looked at it. Looks like the strip gets laid down first then the winshield gets put over it.
Old Oct 3, 2011 | 11:56 AM
sgv2GIS's Avatar
sgv2GIS
I don't think missing a molding would cause wind noise. Windshields are glued to the car with a black urethane. That urethane sticks and seals it and should be water/air proof. The outer moldings are more of a dressing. What you need to do is have a professional come out remove all the moldings around the windshield, reseal it, and then reinstall the moldings. There is a top molding. it sits flush between the glass and roof.
Old Oct 3, 2011 | 01:06 PM
Soap's Avatar
Soap
Yes, I made a mistake thinking I had a top moulding piece missing and that there was a TSB for the side moulding. They are ordering the 2 side pieces and I have an appointment to have them replaced this Thursday. It can't hurt to have them replaced under warranty, and if I still have wind noise I will just take it to a glass shop and see what they can do.
ThumperPup
Apr 24, 2019 09:43 AM
s11d
Dec 3, 2012 03:13 PM
GreatSmile
Dec 28, 2006 09:23 AM
e-man
Oct 1, 2006 10:26 AM
stevechumo
Jun 12, 2005 12:53 AM
