Messed up dash removing vent
Old May 11, 2011 | 07:03 PM
my1s250's Avatar
my1s250
tape it off and plastic dip the little hole
Old May 12, 2011 | 06:43 AM
dat-is350's Avatar
dat-is350
It's around $500 at lexus for the dash.
Old May 12, 2011 | 12:32 PM
Stoodo's Avatar
Stoodo
$500 for a whole dash? That seems like a bargain.
Old Aug 19, 2011 | 08:04 PM
lexuslivin's Avatar
lexuslivin
How much do you think it would cost for a new dash and installation at the dealer?
Old Aug 19, 2011 | 08:50 PM
Dustin2011's Avatar
Dustin2011
On another thread, someone got a quote of $800 in labor to install the dash.
Old Aug 19, 2011 | 08:59 PM
2slixx's Avatar
2slixx
im pretty sure it'll be towards the 800 range.
Old Aug 19, 2011 | 09:30 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
I'd see if you can get it repaired locally, if not, you can get the dash from Sewell for $390.
Installing it would be quite a bit more than that. I'm not sure I'd recommend doing it yourself, only based on what happened to it while trying to remove this vent. There are also other places that may get damaged if you're not careful.
Jeff
Old Aug 20, 2011 | 07:51 PM
sktn77a's Avatar
sktn77a
Shoot a hair dryer at it when the vent is in. This should expand the compression damage from the screwdriver (?) you shouldn't have used!
If that fails, take it to an upholstery repair shop - you'll be amazed at what the can do for $50.00!
Old Aug 21, 2011 | 01:48 AM
comcongen's Avatar
comcongen
How did you damage the dash like that, I'm about to remove my nav for modding
Old Aug 21, 2011 | 10:28 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
You shouldn't pry in that spot. You need to pull down the 4 top tabs from inside the vent, and then pry from the side (after putting tape or something to protect the dash and the prying tool).
Jeff
Old Oct 3, 2012 | 08:08 PM
all06is350's Avatar
all06is350
Originally Posted by Stoodo
I am going to have to do a patch of some kind. Replacing the whole dash would be way too costly labor-wise.
Hopefully I'll come across a vent for a decent price.
I attempted attempted to patch it using leather strips. It is a halfway decent first pass I think.....
Where did you get those strips? I wanna do the same thing. The strips I am finding are all too thick.
ellocovg
Nov 13, 2018 06:25 AM
Lammyyy
Nov 1, 2018 05:58 AM
Jjman79
Apr 6, 2014 12:45 PM
progressiv
Jan 31, 2008 07:10 PM
axis77
Apr 15, 2007 05:34 PM
