Mar 16, 2011 | 04:14 PM
I have a cuestion my car has the brake pads rear and front worn it has anything to do i have 2 lights on my cluster on a triangle that is red and the traction control light it is yellow
the traction control light sometimes it goes off but i have 3 weeks this light are on on my cluster this light are color yellow and it cant go
Reply 0
Mar 16, 2011 | 04:15 PM
If i change the pads both lights will dissapear? .or the traction control light has nothing to do
Reply 0
Mar 16, 2011 | 05:34 PM
When u sober up post the question again
As far as I can tell you have a traction control light on. I don't think that has anything to do with worn brake pads.
Reply 0
Mar 16, 2011 | 05:44 PM
cuestion
Reply 0
Mar 16, 2011 | 05:46 PM
The red one is for the maintenance which is oil change.
You need to restate the question though since its all garbled.
Reply 0
Mar 16, 2011 | 07:39 PM
Worn brake pads shouldn't make those warning lights come on.
Reply 0
Mar 16, 2011 | 08:03 PM
Hey give the guy a break!
I think he means to say that he has the red maintenance light as well as the yellow traction control light on in his instrument panel and would like to know if it has anything to do with worn front and rear brakes.
As someone suggested, the red maintenance light could be a reminder to change your oil. No idea why the traction control light is on though. Does this happen if you turn traction control off? If so, did you maybe accidentally do the pedal dance?
Reply 0
Mar 16, 2011 | 10:23 PM
i dont know why the light is on i change my oil 4 weeks ago what i need to do i have the triangle red light on my instrument panel and the traction control i reset the computer and i desconect the battery and it do not turn off
Reply 0
Mar 17, 2011 | 12:16 AM
Ok, so it turns out the RED TRIANGLE is a master warning light. It can indicate anything from a door being open to malfunction of other vehicle components. That display in the center should give you some sort of message to indicate the problem. Example, when it was time for your oil change, it likely displayed "OIL MAINT REQD", what is it displaying now? Does it say "CHECK VSC"? Check your owner's manual to help you determine what that message means. Once you can pinpoint that, someone will be more likely able to help you.
Reply 0
May 26, 2012 | 01:02 PM
There is a strong possibility that IS250RR is just learning the language, good for him/her to have the courage to ask for help...we are all in this together...The Club Lexus membership!
Reply 0
May 26, 2012 | 01:57 PM
Quote: There is a strong possibility that IS250RR is just learning the language, good for him/her to have the courage to ask for help...we are all in this together...The Club Lexus membership!
As long as they can read! ie. STOP, YIELD, etc.
Reply 0
Subscribe
