Why Different Sizes
Old Jan 2, 2011 | 09:08 PM
06lexichic's Avatar
06lexichic
Default Why Different Sizes
Why does the IS250 have two different size tires???? will it be safe to run the same size all around???
Old Jan 2, 2011 | 09:57 PM
edgeucated's Avatar
edgeucated
There are mutiple reasons why the tires are staggered.
The first is that since the car is a RWD (rear wheel drive) car, then all the power goes to the back two wheels. Therefore, the back two wheels tend to break loose under hard acceleration more readily than the tires in front; having larger, wider tires in the back prevents losing of traction and allows you to utilizing the power effectively. However larger tires comes with increase weight, and since the front tires are only for steering, you don't really need to have the front tires being as wide as the back tires (saving you weight).
yes you can use the same size tires all around, but it gives you no real advantage other than you can rotate your tires
Old Jan 2, 2011 | 10:46 PM
06lexichic's Avatar
06lexichic
ok thanks for the info i was just worried if i put the same tires all around that itll mess something up...
Old Jan 2, 2011 | 11:01 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The IS250 actually does come with the same size all around on some models. All of the AWD models do, and some base model RWD models outside of the USA also do. They came with 205/55R16 all around on those RWD models. I am running 205/50R17 winter tires on my 2011 IS250 RWD which came with staggered 17's without any issues.
Jeff
Old Jan 2, 2011 | 11:36 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
The only problem i can see with running the same size tires front and rear, is that the wheels are different widths from and rear. 18x8 front and 18x9 rear... that is, if you have 18's. The 17's im pretty sure are different widths as well, as the 17 inch wheels had 225's and 245's...
Old Jan 3, 2011 | 12:05 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The 17's are 17x8 all around, the 18's are 18x8 in the front and 18x8.5 in the rear.
16-inch RWD: 205/55R16 front & rear (16x7.0" - Not sold in the USA)
17-inch AWD: 225/45R17 front & rear (17x8.0")
17-inch RWD: 225/45R17 front, 245/45R17 rear (17x8.0")
18-inch RWD: 225/40R18 front, 255/40R18 rear (18x8.0" front/18x8.5" rear)
Jeff
Old Jan 3, 2011 | 08:15 AM
Kurtz's Avatar
Kurtz
16-inch: 205/55R16 front & rear (RWD, 16x7.0")
17-inch: 225/45R17 front & rear (AWD, 17x8.0")
17-inch: 225/45R17 front, 245/45R17 rear (RWD, 17x8.0")
18-inch: 225/40R18 front, 255/40R18 rear (RWD, 18x8.0"/18x8.5")
Jeff
Be careful.
That's in Canada.
In the US 16" wheels don't exist, and the 17s are not the same tire front and back (on RWD models)
Old Jan 3, 2011 | 09:03 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Read my list again, I never said they were the same front and rear.
I know 16's weren't sold in the USA (They aren't sold in Canada anymore either), but that doesn't really affect anything, does it? My list is accurate. If your car came with 16's, that's the size they would be, haha.
Jeff
Old Jan 3, 2011 | 11:01 AM
Kurtz's Avatar
Kurtz
The IS250 actually does come with the same size all around on some models. The AWD models do, but the base model RWD models also did.
That second quote is what I was talking bout... the "base model RWD" in the US is 17s... (which is why mentioning the lack of 16s is relevant) and which indeed even in your list shows they aren't the same size tires all around. ALL rwd models in the US have staggered wheels.
Old Jan 3, 2011 | 11:39 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
You are correct, if we are talking specifically about the USA, the RWD models never had the same size all around, and they never had 16's.
The original poster was asking if there would be any issue running the same size all around, and I was just saying base model RWD's came with the same size all around. Just because Lexus USA never sold them that way doesn't mean it's not true.
I wasn't trying to say what you could and couldn't get in the USA, just what was available on the IS. The car is the same either way. My posts were to show what sizes Lexus offered on the IS.
The list I posted is accurate globally, it is not US-specific. I didn't see the need, but I've edited my post anyways.
Jeff
malba2366
LX - 3rd Gen (2008-2021)
Sep 19, 2018 03:28 PM
Cobra19
Oct 5, 2012 05:33 AM
Nicelex13
Wheels, Tires & Brakes Forum
May 25, 2010 08:31 AM
blkhawaii
Jun 8, 2006 03:04 PM
