Im a proud new female owner of a 2010 black on black IS250AWD.
I recently purchased a set of illuminated scuff plates from Sewell (this will be my first mod). I've done searches on CL to figure how to wire them up. The thread say to cut the grey wire from the sill and connect to a new wire running to the door switch wire. The two wires from my set of sills are red and brown. So im really confused now, I cant find a grey wire. Am i missing something here?
Thanks
Yeah I'll confirm as well that there should be a connector in there in all 2007+ IS models which should make the plates plug and play. Unfortunately no one has confirmed if this is true outside of the US though the vehicles should be near identical considering it came out of the same plant.
I'm not sure if the cars are different over there in BC but ummm mines jus plugged right in to a connector that was prewired from factory
The car is generally the same. The only noticable changes is the instrument cluster and the NAV/Climate display is that it is in the metric system (ie. Kilometers is on the outside, MPH inside, Temperature display is in Celcius and L/100KM) for the Canadian cars. If was also told there isn't a service light that goes off if it's time for service like the US cars have.
I wish I could have my US car modified to use Canadian displays (I prefer the Canadian way!!) but Lexus saids it cannot be done. Seems like a simple plug and play swap with the Canadian part unless there are other things involved which I am not aware about.
