Old Dec 16, 2014, 11:40 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
LED Lighting Replacement Guide (w/Pics)
Old Feb 4, 2014 | 02:36 PM
  #661
TaninAuto's Avatar
TaninAuto
Sponsor
921 I have on the way. What type of brightness do you want on the 9005?
Old Feb 4, 2014 | 02:38 PM
  #662
dorkacho's Avatar
dorkacho
was looking for 6000k , thanks!
will decoder fit or does it require cutting, etc, like ijdmtoy older models?
Old Feb 4, 2014 | 04:30 PM
  #663
Raybean's Avatar
Raybean
the big fat Decoder ijdmtoy sells will not fit into the headlight housing. u going have to leave the dust cover off, i have read some guy broke the covers off and wrapped it with electric tape or drill a hole in your dust cover and run the wires though it and seal up that hole.
Old Feb 4, 2014 | 06:05 PM
  #664
dannyboy26's Avatar
dannyboy26
I was able to fit mine into the housing it takes a little squeeze but fits right in I kind of angled it and worked it in slowly... Leaving cover off is a nonono will see moisture in your headlights
Old Feb 10, 2014 | 07:03 PM
  #665
TaninAuto's Avatar
TaninAuto
Sponsor
921 LEDs are in stock. $14.99 each. Super bright.
http://www.taninautoelectronix.com/T...p/921_cree.htm
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
https://taninjdm.com/
Our Lexus LS430 Dealership
Old Feb 11, 2014 | 05:42 AM
  #666
CBlex06's Avatar
CBlex06
Very helpful info
Old Feb 15, 2014 | 09:14 PM
  #667
RR601's Avatar
RR601
2011 Ls460 wanted to replace the front dome light and maybe the rear dome. Understand some had a problem with the key fob acting strange. Would it be less of a risk changing the bulbs if I went with the less bright ones.
Thanks
Old Feb 16, 2014 | 02:07 PM
  #668
dorkacho's Avatar
dorkacho
^ what's wrong?
Old Mar 27, 2014 | 02:51 PM
  #669
lilpub3's Avatar
lilpub3
hey could somebody guide me to an updated working link for the 5000k ultra bright trunk led circuit board please? much thanks
Old Mar 27, 2014 | 05:18 PM
  #670
daileycon's Avatar
daileycon
Are these the bulbs I need to replace the yellow looking DRL's in a 2010 IS250? Do I need some kind of decoder people are talking about? Total noob when it comes to lighting (and everything else actually haha)!
http://www.vleds.com/bulb-type/dayti...45-1-pair.html
Old Mar 27, 2014 | 05:48 PM
  #671
dannyboy26's Avatar
dannyboy26
Originally Posted by daileycon
Are these the bulbs I need to replace the yellow looking DRL's in a 2010 IS250? Do I need some kind of decoder people are talking about? Total noob when it comes to lighting (and everything else actually haha)! http://www.vleds.com/bulb-type/dayti...45-1-pair.html
Yes yo do need a decoder I just sold a pair actually... But you can even get them from amazon
Old Mar 27, 2014 | 06:05 PM
  #672
daileycon's Avatar
daileycon
Thanks, it looks like this option comes with the decoders but is only 5k
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r4.htm
or
http://www.ebay.com/itm/2x-9005-LED-Headlight-Fog-Light-DRL-No-Error-Load-Resistor-No-Flickering-Decoder-/171076941314?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d4faf602&vxp=mtr
Old Mar 28, 2014 | 01:38 AM
  #673
dannyboy26's Avatar
dannyboy26
The iJdm ones are the ones I sold and look like my 6k blue HIDs
Attached Thumbnails LED Lighting Replacement Guide (w/Pics)-image-2112188242.jpg
Old Sep 19, 2014 | 11:18 AM
  #674
mrfresh's Avatar
mrfresh
Originally Posted by supaIS350
brociouz,
How do these compare to the LED light kit from Sewell? I am thinking about getting those. I don't really care for brightness. Just really want the LED coloring instead of the yellow bulbs.
Agreed... That brightness looks blinding!!!!
Old Oct 22, 2014 | 01:45 PM
  #675
5nX37's Avatar
5nX37
Default LED headlight bulb
So I decided to not go HID but instead went with LED headlight bulbs to replace my stock halogens. This is more of a feedback from my experience as I haven't seen any info on how LED headlight bulbs perform. I'm referring to the newer designed CREE type LED with cooling fins and driver relay harness designed for headlight application not the older design with the SMD clustering all around the bulb..
LEDs have been the latest technology in lighting so I figured I give this a shot. Anyhow, when I got the bulbs I was impressed at how they were packaged..it was like unboxing a smartphone or some high end mobile device. The bulbs appear to be in high quality fit and finish. Installation was easy and the wiring harness all fit right inside the headlight housing. No bulky ballast or drilling needed.
After installing, the lights turned on without any issues. The color was spot on; 6K diamond white. The cutoff was clean but how the light spread out was too narrow. If compared to HID and halogen as it's lit up at the ground, the cut off is more like a wide U shape, while the LEDs have more of a narrow V shape. The light output was fairly as bright as HID but again isn't as spread out widely as HID.
Overall it's a great product but its performance to me just wasn't as good as HIDs. I'm guessing this explains how newer vehicles, that have the LED headlight technology, have more than 1 bulb per headlight to achieve extreme brightness. I am no headlight expert but just wanted to give my feedback on this product. This is as to not deter others from trying them out for yourselves. That said I'll be exchanging them for a pair of HIDs.
