Climate Control Problem?
Old Jun 1, 2010 | 12:57 PM
drlovegun's Avatar
drlovegun
Default Climate Control Problem?
We have an '06 ISswo AWD without nav. Until recently, when you shut the car off with the air/heat system on it is automatically on when you re-start the car.
Lately it doesn't automatically start up. Instead the button that says "Front" on it (for the defrost) blinks yellow 4 or 5 times and then nothing happens unless you hit "Auto" to turn everything on.
This isn't a huge problem obviously, but strange that it's started happening. The other oddity is the cigarette lighter next to the ashtray no longer works either.
Is this possibly a fuse issue?
Old Jun 2, 2010 | 08:07 AM
drlovegun's Avatar
drlovegun
Anyone have any idea on this?
Old Jun 17, 2010 | 03:45 PM
drlovegun's Avatar
drlovegun
Default Hello and I have a question!
Hi there, glad I found this site, seems pretty informative. I have a quick question that I need some help with if you don't mind.
We have an '06 IS250 AWD without nav. We're creeping up on 100K miles.
Also have noticed that if the car is off for only an hour, the climate control is on immediately, but not if the car's been off for over 2 hrs.
Is this possibly a battery issue?
Old Jun 21, 2010 | 01:12 PM
drlovegun's Avatar
drlovegun
Default New here and I have a question please
Old Jun 21, 2010 | 10:05 PM
acefalcon2's Avatar
acefalcon2
for the cigarette lighter... might wanna check the fuses... sometimes it trips...
Andre
Old Jun 23, 2010 | 11:11 AM
E6BAV8R's Avatar
E6BAV8R
For the A/C light blinking, check the owners manual.
I read if you are trying to turn the AC on and the light blinks multiple times that there is a fault with the A/C system. That is probably why it is not automatically turning itself back on when you start-up, and why it blinks when you turn it on.
Old Jun 23, 2010 | 04:42 PM
drlovegun's Avatar
drlovegun
Thanks for the suggestions! I'll look into both
Lexi250awd
Oct 16, 2018 10:24 AM
amjadLS430
Mar 17, 2014 07:08 AM
bergynator
Jan 29, 2013 05:59 PM
Arbitrage1
Jan 29, 2008 06:06 AM
looknow12
Maintenance
18
Dec 14, 2002 03:09 PM
