Front Size 17X7.5
Offset +45
Rear Size 17X7.5
Offset ET +45
Bolt Pattern 5x114.3
Hub Bore 60.1
Stock AWD Wheel size:
F & R 17x8 45mm offset 5x114.3 - Tire 225/45/17
Those LFA reps will fit just fine, as they have the same offset. The wheels are 0.5mm less wide than the stocks, but that wouldn't be a problem. But at 17", there's going to be some pretty heavy wheel gap without lowering.
Oh thanks I didn't know there was an AWD thread.
But since we're already here, The wheel gap won't bigger than how it is w/ stock wheels since its basically the same size right?
I'm thinking about picking a set of Reversed mounted LM in size 18x9, 18x10 +7. Is it possible to make it fit? Or I can just mount the face the regular way and change the offset back to 30s. What do u guys think?
1. Your link does not work
2. 18" and +45 offset is fine.
3. I don't own a AWD so I don't know the effects of staggered tires on the drive train. However, I've heard staggered combinations work. Better check this thread: https://www.clublexus.com/forums/is-...-part-uno.html
Are you lowered? Will you be willing to modify your fenders, camber, etc to make them fit?
Personally, I think it's better to reverse it back to 30s offset.
Hi CL,
I tried to search but no luck so far so i thought i asked yiu guys. How will 19x8.5 +34 and 19x9.5 +34 look on a rwd is250? Pics/link will be great
And do you think i can tuck my tires without modifying fender and no rub? Tires will be 225/35 and 245/35 .
Thank you in advance
Hi CL,
Also, F-Sport springs won't have a noticeable drop, so it won't be much different than the issues those guys are running into - which are mostly rubbing on the fender liners.
Currently running 19x9.5 +35 up front no issues after extensive inner fender work.
Yesterday I had both front fenders widened, re_painted, shaved, and removed fender liner. Can a 20x10.5 +45 fit up front? Or will it hit stock suspension arms?
