Will those wheels fit? START HERE.
Old Dec 13, 2012 | 11:25 AM
  #4066
bob4256's Avatar
bob4256
Originally Posted by ZNation
Got a deal on wheels and tires. Just want to make sure it should all fit!!!
Wheels are 17x8 +25 Front and 17x9 +42 Rear
Tires are 225/45/17 Front and 245/45/17 Rear
Should be a pretty straight forward fit right?
2006 IS250 RWD
Im no wheel expert, but based on that +25 offset for your front wheels your going to have to roll your fenders and maybe relocate the fender tab.
Just an educated guess since Ive been stalking this thread for a bit and trying to learn a thing or two
Old Dec 13, 2012 | 12:10 PM
  #4067
ZNation's Avatar
ZNation
Thanks, would you happen to know if another offset would work in the front? I'm terrible with this offset stuff right now. Wish I could understand it better. The wheels come in a few offsets, the shop recommended +25, so now im rethinking.
I believe the wheel comes in all the following:
+35
+48
Im thinking the +35 should be good?
Old Dec 13, 2012 | 12:30 PM
  #4068
bob4256's Avatar
bob4256
+35
+48
I dont want to answer this because I might be wrong so Ill wait for Projectdna or another wheel guru to respond.
For your reference: I previously had a +32 offset up front on my Vossens and I used to rub at first when making medium to sharp turns. After a while I only rubbed when making sharp turns. I am lowered on Megan EZs btw
Old Dec 13, 2012 | 12:38 PM
  #4069
Vroomin350's Avatar
Vroomin350
2006 IS250 RWD
First
Why 17's? They are going to look tiny on your car.
Second
Every single choice you posted will work with very minimal work. Infact the only one that you MIGHT need to roll your fenders in the front are the 8+25.. again I would look at a different set of wheels, unless these are costing you $200 its not worth it.
Old Dec 13, 2012 | 12:53 PM
  #4070
ZNation's Avatar
ZNation
Originally Posted by Vroomin350
First
Second
The price was very fair and I actually dont mind the look of my stock 17's The car is low enough that 17" works well. 18 would be sweet, but in the long run, im not looking at burning through 18" rubbers all the time. Anything bigger than 18 would just be too aggressive for me.
We'll see what you guys think when it comes time to put them on in a few months.
Old Dec 13, 2012 | 01:31 PM
  #4071
Mv350's Avatar
Mv350
Ya you might need to do a slight roll to e safe up front. But you should be about right with that 17" setup
Old Dec 13, 2012 | 05:10 PM
  #4072
Slammer1's Avatar
Slammer1
Okay, I'm about to buy a set of Motegi MR125 wheels in satin black for my '06 IS350 and have a quick question about the rear offset. The fronts will be 18x8 and +45 (factory) but the rears will be 18x9 and +35. Factory rears are 18x8.5 and I am curious as to whether the 9s will push the rear wheels out slightly or not. I am lowered on F Sport springs and love the look but the sidewall of the rear tires is flush with the lower part of the fenders but is inset by about an inch at the top. I'm sure these will "fit" properly, but hope that they will be pushed out slightly at the top?
Old Dec 13, 2012 | 06:00 PM
  #4073
Vroomin350's Avatar
Vroomin350
Hey man no problem its your car and dont worry about what others think. I am just tyring to share my experience, 18's (I am on) already almost look too small, IMO 17's are for the snow, that's the only time this car should be running that size, especially dropped.
You will be fine however you rear wheels will be considerably flusher than your fronts.
Old Dec 13, 2012 | 06:03 PM
  #4074
Slammer1's Avatar
Slammer1
Sweet.....
Old Dec 13, 2012 | 11:07 PM
  #4075
Jaydemm's Avatar
Jaydemm
2006 IS250 RWD
front 18x9.5 with 215/40/18 tires
back 19x10.5 with 235/35/19 tires
will these fit?
Old Dec 13, 2012 | 11:39 PM
  #4076
projectdna's Avatar
projectdna
Originally Posted by Jaydemm
2006 IS250 RWD
will these fit?
you'll need to provide offset information, but assuming you're going with low-offset wheels, you'll need fender modifications if you're going to stretch tires over those wheels.
on an unrelated note, running 18's in the front and 19's in the rear will look awkward - especially if you're stretching tires. retarded also comes to mind, but i guess if you're into that then by all means have at it.
Old Dec 15, 2012 | 10:40 AM
  #4077
Stavros's Avatar
Stavros
2006 IS 250 RWD
stock height
front 18x9 ET35 with 235/40/18
rear 18x10 ET45 with 265/35/18
I want to avoid any fender / bumper tab mods if possible.
Will those fit without rubbing?
Thanks
Old Dec 15, 2012 | 02:57 PM
  #4078
2jzpwr808's Avatar
2jzpwr808
how about these wheels work VS-XX
18x8+36 (A-DISK) 225/40/18
18x10+36 (A-DISK) 255/35/18
any modifications needed?
Old Dec 15, 2012 | 08:17 PM
  #4079
Uda880's Avatar
Uda880
I'm not a pro like ProjectDNA, but trying to help wherever I can.
Any suspension mods? Depending on how low you are, the tire sizes and rear offset "may" be a problem.
But if you're stock, both offset and tires are fine - rear may be slightly aggressive +36 (I ran a +40 19" and it was fine), and your rear tires are slightly shorter than stock (255/40/18).
Old Dec 15, 2012 | 08:29 PM
  #4080
Uda880's Avatar
Uda880
Originally Posted by Stavros
2006 IS 250 RWD
stock height
Thanks
Again, not as awesome as ProjectDNA, but trying to help with quick answers.
Offsets are fine at +35/+45. Usually rubbing begins to appear with 19" +35 wheels (with a wheel diameter of 482.6mm as compared to your 457.2mm (a ~25mm difference), as the plastic fender liners will touch on 40 degree turns.
Tires "may" be problematic:
      But since the general adage is to avoid having more than a 5% diameter difference, both tires would be just fine with that set up at stock height.
