Will those wheels fit? START HERE.
Old Nov 18, 2011 | 08:44 PM
  #2806
MyIS350G's Avatar
MyIS350G
Originally Posted by projectdna
3 millimeters.
thanks, thats what I thought, below is my rear wheel 20x10 +20, sticking out too much imo, now the wheel company said they can shave 3mm of the base. Will that change much as far as how much theyre sticking out?
Old Nov 19, 2011 | 04:44 PM
  #2807
Ikon_Vin's Avatar
Ikon_Vin
Im thinking of picking up some rims off of someone, 20x9f and 20x10r w/ 22offset. I got Project Mu BBK front and rear. So Im wondering WILL this fit? How much poke-age are we talking about? Tire size recommendation? Thanks
Old Nov 19, 2011 | 05:11 PM
  #2808
projectdna's Avatar
projectdna
-pic snip-
3mm isn't a huge visual difference.
given that much poke, it would have to be at least 10mm.
yes, some, 225/30-19 + 245/30-19.
Old Nov 19, 2011 | 06:13 PM
  #2809
AznK's Avatar
AznK
HI,
New to the forum and looking for some experienced help.
I'm wondering if 19x8.5 +30mm and 19X9.5 +24mm will have rubbing issues
would running 235/40/19 and 265/35/17 tires be ok for my AWD system?
I'm lowered on F-Tune springs.
Thanks for your time,
Jon
Old Nov 19, 2011 | 09:38 PM
  #2810
MyIS350G's Avatar
MyIS350G
Originally Posted by AznK
HI,
Jon
For springs you should be fine in the front but the rear with 19x9.5+24 with 265 series you might rub not big bumps, get your fender rolled/
Old Nov 20, 2011 | 12:45 AM
  #2811
projectdna's Avatar
projectdna
HI,
Jon
those tire sizes won't work with your proposed wheel specs.
225/35-19 in the front, 245/35-19 + rolled fenders in the rear.
Old Nov 20, 2011 | 01:15 AM
  #2812
AznK's Avatar
AznK
Thanks for the quick response
Thank you so much, you guys saved me a ton of time and worry.
Jon
Old Nov 20, 2011 | 03:15 AM
  #2813
Rash's Avatar
Rash
hmm
Originally Posted by starknight
I got a set of varrstoen rims
front: 19x9.5 +22
rear: 19x10.5+22
I am lowered on fsport shock and spring. will I get any rubbing issue? what size of tires should I use to avoid rubbing?
I will get coils.
The fenders should be pulled? can't seem to find anyone can do that for me in where I live. Only rolling. Which one needs pulling front or rear?
Old Nov 20, 2011 | 10:00 AM
  #2814
DocFreud's Avatar
DocFreud
ouch... but i suppose that's to conform to the german TUV standards (aka "autobahn-worthiness"). another reason to buy authentic, but i digress.
you can try using bolt pattern adapters (5x114.3 to 5x120) so you can run BMW wheels, though i don't know if you can find a set that are TUV approved. maybe eibach and/or H&R would retail those adapters?
ya it is all about the standards, which are really high. around here you can't even think about redrilling bolt patterns or cutting springs. the tüv inspectors will get a heart attack if you tell them about these things. god im so jealous of everyone who has not to deal with such a cluster****.
edit: ahh i forgot to post another question
whats the difference between rolling and pulling the fenders?
edit2: oh funny, i am not allowed to say ****.
Old Nov 20, 2011 | 06:48 PM
  #2815
projectdna's Avatar
projectdna
Originally Posted by Rash
I will get coils.
it's more like a roll-pull: as the fenders are being rolled, the natural force of the fender roller wheel pushing on the inside of the fender pushes - or "pulls" the fender outward. instead of splitting hairs as to what it should be technically called, but the end effect is that - pulled fenders.
so to answer your questions, yes - albeit slightly, and both.
i am so sorry to hear that. i would ask eibach or H&R if they have any spacers so you can run effective offsets (vs. pure offsets). i think H&R does. use spacers to lower the effective offsets so you can still get the stance that that 2is has in that link in your previous post.
the difference between rolling and pulling the fenders is what you're doing to it to achieve the same goal: create as much clearance as possible for aggressive offset wheels and/or wider tires. rolling keeps the body lines by "rolling" the inside lip of the fender flat, while pulling widens the fender edge and basically alters the body lines.
Mv350 should be able to demonstrate what pulling is.
Old Nov 20, 2011 | 10:01 PM
  #2816
panda_ek9's Avatar
panda_ek9
so im looking into getting some 20x8.5 +32 front and 20x10.5 +30 rear.. will these fit?? what rubber should i use?? fender mods?? im sitting on tein s-tech springs
Old Nov 20, 2011 | 10:55 PM
  #2817
projectdna's Avatar
projectdna
yes, those will fit.
225/30-20 + 245/30-20.
may not need fender mods up front, will need them for the rear.
Old Nov 21, 2011 | 01:10 AM
  #2818
A_Grasso's Avatar
A_Grasso
Hey CL, I'm going to be putting on a set of 19's pretty soon and I'm not sure if they will look good. The specs are 19x8.5 +14 with 3 inch lips all around. I know that I'll have to roll my fenders and maybe even pull, but with those offsets will the wheels poke out too much from my fenders? Also, what size tires would you suggest? I daily drive my car and take it on canyon runs a few weekends out of each month. Any feedback would be appreciated!
Old Nov 21, 2011 | 01:14 PM
  #2819
DocFreud's Avatar
DocFreud
ahh thanks.
I think I will just wait until Rota brings the linea corse 818 to germany.. their german homepage says coming soon.. If if buy the same wheels from my link, I will get the same stance, without spacers right? though getting spacers would be no problem
edit: ahh forget it, the questions was answered before, thanks anyways
Old Nov 21, 2011 | 03:08 PM
  #2820
projectdna's Avatar
projectdna
you're going to have to roll and pull the fenders and run 215/35-19's; 225's will be too upright for the clearance required. and depending on how low your ride height is, you'll need to shave the fender tabs (or shave them off altogether).
you can make it work for daily driving, but if/when you decide to push it you'll you won't enjoy the aggressive offsets and semi-stretched tires.
i'd recommend a staggered set-up with something wider than 255 in the rear. otherwise, you'll just be fighting for steering response up front and traction in the rear...
ahh thanks.
no problem. hope you can find the properly-spec'd wheels that pass TUV regulations. you shouldn't have issues w/ running spacers if it comes to that - especially spacers that are TUV-approved.
on a related note and personally speaking, i'm a firm advocate in authentic wheels that pass JWL/VIA/TUV testing (DOT-approved is a sub-par standard). unfortunately, i'm labeled as an "elitist" or a "brand snob" because of that... /OT
