Will those wheels fit? START HERE.
Old Oct 22, 2011 | 05:02 PM
  #2686
Cobbler's Avatar
Cobbler
Sorry for is350
Originally Posted by Cobbler
I need some help.
Picking up some staggered wheels
19x8.5 +35 in the front
19x9.5 +25 in the rear
73.1 bore
What size tires would I need to have the best look? Would i need fender work? Can i get away w +20 in the front?
Thanks guys!
Old Oct 22, 2011 | 09:42 PM
  #2687
SCWB's Avatar
SCWB
Originally Posted by BamaIS
Thanks man. I have located a couple of 235/35/19 Micheline PS2s with about 75% tread I can get pretty cheap if the 225/45s rub. I'm meeting him in about an hour so I'll know real soon.
EDIT: UPDATE: With the sport suspension I rubbed the plastic liner like crazy. The 225/45 was way too tall. I am currently running 235/35 on the front with my 15mm spacer. I rub slightly on extreme bumps. In the rear I'm running a 255/35 with my 20mm spacer and I'm rubbing at the top of the wheel well on the lip. I'm going to have to shave a few mm off the fender lip or get a smaller spacer to avoid rubbing. I love the look of it though.
Is the rubbing better or worse after you change your rear tires to 255-35-19??
How big (or How wide) is the tire-to-fender interference with your current set up right now?
Old Oct 23, 2011 | 07:47 PM
  #2688
pbm317's Avatar
pbm317
Would SC430 rims with 235/40-18's fit an IS350 rwd?
Friend has an old set of winter tires on the SC430 rims and I was wondering if they'd be ok on the IS350
Old Oct 23, 2011 | 08:52 PM
  #2689
Vroomin350's Avatar
Vroomin350
I wonder what might cause your lip to rub the fender with the 20mm. I am at 19x10.5+33 rear and a lot lower. I rub tire but not lip.
when I had the 15mm spacers on my lip did hit the fender.
Old Oct 23, 2011 | 08:58 PM
  #2690
starknight's Avatar
starknight
I got a set of varrstoen rims
front: 19x9.5 +22
rear: 19x10.5+22
I am lowered on fsport shock and spring. will I get any rubbing issue? what size of tires should I use to avoid rubbing?
Old Oct 23, 2011 | 10:51 PM
  #2691
projectdna's Avatar
projectdna
Originally Posted by FreshIS250
I am trying to find out what tire size in the rear I can run... rear wheels are 20x10 with a ET45... I'm guessing this is the offset
2007 is250 lowered on road magnet springs with a 2inch drop all around
265/30-20
Originally Posted by waitwat
F/R: 18x8.5 +30
on a 2inch drop is the offset too low and will that ride good with out fender modifications? i dont want meaty tires either
im a noob please respond
i dont wanna modify my fenders so any suggestions would help
staggered oem 18" tire sizes. search is your best friend.
I need some help.
73.1 bore
Thanks guys!
225/35-19, 245/35-19.
fender work is a must in the rear.
you can run +20 in the front but you'll need fender work and 215/35-19.
don't know. what are the specs of your friend's sc430 wheels?
front: 19x9.5 +22
rear: 19x10.5+22
fender mods are a must. roll + pull. shaved fender tabs.
you can try 225/35-19 + 245/35-19 for the stretched look.
max width is 235/35-19 + 265/30-19? Mv350 should have a better idea.
Old Oct 24, 2011 | 06:16 AM
  #2692
Mv350's Avatar
Mv350
on springs you're gunna have crazy poke, please dont do it
almost like this
get some coils, and if you are going to still do it, youll have to run 215/35 and 235/35 to get the stretch you need
on coils you can run up to a 225/35 and 245/35 and with pull you can go bigger
Old Oct 24, 2011 | 06:37 AM
  #2693
BamaIS's Avatar
BamaIS
It was actually a little worse. Saturday I shaved about 1/4" off the rear lip and I have no rubbing now.
Old Oct 24, 2011 | 09:07 AM
  #2694
pbm317's Avatar
pbm317
They are the stock 2002 SC430 rims, with the giant covers...
18x8 with the 5X4.5inch
Just wondering if that with the 235/40-18's all around would be okay.
Old Oct 24, 2011 | 09:42 AM
  #2695
projectdna's Avatar
projectdna
wheel offsets?
not that i don't want to tell you if it fits or not, but just because it's 18x8 w/ 235/40-18 tires doesn't mean it'll bolt right up and clear is350 brake calipers.
Old Oct 24, 2011 | 12:44 PM
  #2696
pbm317's Avatar
pbm317
i believe they're +45 all around
Old Oct 24, 2011 | 02:30 PM
  #2697
jgonx213's Avatar
jgonx213
i was wandering if i drop 2inches with road magnets and rims spec
19x9.5 +30 fronts tires:225/35/19
19x10.5 +30 rears tires: 245/35/19
will they fit after i drop 2inches
Of course imma roll my fenders and stretch my tires
if anyone has this rim spec, can i see a picture? and state what ur on for suspension?
Old Oct 24, 2011 | 04:08 PM
  #2698
Vroomin350's Avatar
Vroomin350
^^ I THINK you'll get away with it I run the same suspension and very close offset. It was at +27 that my lip was hitting the fender.
Old Oct 25, 2011 | 11:26 AM
  #2699
sang26's Avatar
sang26
I was thinking about buying the varrstone 1.1.2 they come in 19x9.5 offset 22 front. 19x11offset 22 in the back , would I need any fender work? If so what kind? And what kind of tires should I run?
Thank you
Old Oct 25, 2011 | 11:50 AM
  #2700
steezy's Avatar
steezy
Thank you
the front, needs a slight pul and shaving for the tab. the rear needs A LOT of work. Probably a 1.5'' to 2.0" pull. tire sizes you could go 225/35 front and try a 245/35 rear. if not then 255/35. the 245 for 11" rear might be too stretched but my friend did it and it looked sick.
