Will those wheels fit? START HERE.
Old Aug 22, 2011 | 08:15 PM
  #2506
hydralisk's Avatar
hydralisk
18x8.75 is real? Why so skinny?
Old Aug 23, 2011 | 02:39 PM
  #2507
eternal07's Avatar
eternal07
can't do hellarflush for now
I wanted 9" in rear and 8" in front but they dont make that size...
Old Aug 23, 2011 | 03:31 PM
  #2508
projectdna's Avatar
projectdna
doesn't matter how wide the wheels are; it's the tires that are making contact with the road.
unless he's trying to max out the widest tire he can fit on those wheels, there's little relevance to calling those wheels "skinny".
i'd stay w/ the 8.75" up front and go wider in the back, but a square set-up w/ same-sized tires at all four corners allow you to rotate the tires and get more life out of them.
Old Aug 23, 2011 | 05:05 PM
  #2509
is150's Avatar
is150
Im going to be modding the front bumper/fender tab tomorrow. Do you guys prefer the method of shaving the tab down and relocating the screw, or bending the tab up? I ask because i am planning on notching the tab past where the current screw is, heating it all up, and bending all (metal tab, oem screw, bumper tab) of it up.
Old Aug 23, 2011 | 05:11 PM
  #2510
Mv350's Avatar
Mv350
cut it off, bending it doesnt do the job, trust me
Old Aug 24, 2011 | 09:50 PM
  #2511
100degrees's Avatar
100degrees
Does anyone know whats the minimum size spacers needed for ISF rims to clear the front brakes of an IS350?
Just picked up a set of ISF rims off ebay and totally forgot spacers were needed. I'd like to get the smallest spacer possible that will allow them to fit. Thanks!
Also will ISF tpms sensors work w a 2IS?
Old Aug 24, 2011 | 10:23 PM
  #2512
projectdna's Avatar
projectdna
1. i don't know, but based on the pics in the first post of this thread my guess would be 10mm to be on the safe side?
2. IS-F TPMS sensors will work w/ a 2is, but you will have to get them reprogrammed.
Old Aug 24, 2011 | 10:32 PM
  #2513
100degrees's Avatar
100degrees
Thanks I read that post too. I'm concerned with the studs being too short. Is 10mm safe to run on stock studs or will I need to get extended studs/spacer w studs in them.
Old Aug 24, 2011 | 11:28 PM
  #2514
jzafra88's Avatar
jzafra88
I have staggered OEM front 225/40/18 and rear 255/40/18
Looking to get TSW willow 18 x 9.5 and use with the OEM tires. Will that wheel size fill all around?
Old Aug 25, 2011 | 12:37 AM
  #2515
projectdna's Avatar
projectdna
extended studs are recommended.
see my response in your thread.
Old Aug 25, 2011 | 09:40 AM
  #2516
Mv350's Avatar
Mv350
They are needed or get spacers with them pressed in already. I changed the studs out on my IS up front. tap them out with a hammer. take an open ended steel lug nut and an impact wrench. and pull them back through. after check the torque on your lug nuts for about a week every so often and they will fully seat without a problem. make sure to pull the stud through as much as possible.
Old Aug 25, 2011 | 05:09 PM
  #2517
100degrees's Avatar
100degrees
thanks for the input! I think im going to use the ichiba v2 that already have the studs pressed in. i just purchased 5mm spacers. waiting to order 15mms. I will report back if the 5mm works on isf rims
Old Aug 25, 2011 | 08:17 PM
  #2518
7PANGET's Avatar
7PANGET
hi guys!!! im plannning to get WORKS GNOSIS GS2.
front: 19x9 +30 or 19x8.5 +35
back: 19x10 +35
im lowered on fsport springs
any rubbing problem and fender rolling?
what tires should i run?
Old Aug 25, 2011 | 10:01 PM
  #2519
Vroomin350's Avatar
Vroomin350
GNOSIS GS3
Wheels fit AWSOME on stock fenders and with no spacers, looked flush. But it wasn't enough for me
Read below.
Bro am about to pull the last hair on my head, I need your advice.
Remember my specs
19x9+30F 225/35/19
19x10.5R+42 245/40/19
I added a 15mm spacer in the rear, puts me at +27 if I am correct. In the rear I RUB. Worst part is I have shaved the infamous metal tab, rolled and pulled my fenders. Something is still shredding the lower part of my tire sidewall (close to the rim)... Any ideas?
I was thinking maybe camber,
What camber are you running?
Any help would be appreciated?
Old Aug 25, 2011 | 10:14 PM
  #2520
Vroomin350's Avatar
Vroomin350
By the way the fenders have been rolled twice, went back to him after thinking a proper job wasn't done the first time. Went to Anthony the famous Miami fender rolling king, great guy and wasn't offended at all, instead he did everything all over again. I highly recommend him. Someone please chime in.
