Do you have CLOCK DIMMER?
Old May 26, 2009 | 01:27 AM
Lohus's Avatar
Lohus
Default Who can measure the voltage on the clock assembly? (edited: Do you have CLOCK DIMMER)
Preamble: I've retrofitted OEM monitor/navi to the non-navi car, but one wire left not connected... With the help of our club members we clarified that this wire stands for the clock illumination (other words dimming in low light conditions).
Amble: Now I need to know the voltage on that wire (brown wire on the 1st pin of the clock assembly connector), when the headlights are on\off and when the light sensor is closed (low light conditions).
P.S. No, you dont need to remove nav unit to measure the voltage, just remove clock assembly (as you do when you want to change the navi dvd disk), and measure the voltage on the brown wire with voltmeter...
Old May 26, 2009 | 04:16 AM
Rash's Avatar
Rash
hmm
Clock dimmer? Does that annoy you?
Old May 26, 2009 | 04:27 AM
Lohus's Avatar
Lohus
Just want to know if I messed up with my wiring...
Old May 27, 2009 | 05:41 AM
Lohus's Avatar
Lohus
So, nobody could check such a simple thing?
Old May 27, 2009 | 01:08 PM
2slow's Avatar
2slow
Your car is a 09 am i correct? On my 07 there is one dimmer, and it dims the cluster and all the navigation buttons.
How would you mess up your wiring if you know nothing about the car?
Old May 27, 2009 | 01:27 PM
Lohus's Avatar
Lohus
You didn't answer the main question - does your clock dims too (together with cluster and navi buttons)?
Know nothing about the car? I've successfully retrofitted OEM monitor+navi unit myself, but one wire left not connected... That's why I'm asking about the clock dimmer feature...
Old May 27, 2009 | 06:21 PM
IS350jet's Avatar
IS350jet
The clock does not have a manual dimmer. However, it will dim slightly when the headlights are turned on.
Old May 27, 2009 | 07:57 PM
2slow's Avatar
2slow
I don't think the question "does your clock have a dimmer" is the correct question to ask. You should take a picture of the wire that is left disconnected but the guy above answered your question. It does not dim manually, but only when you turn your headlights on.
Congrats on the retrofit.
Old May 28, 2009 | 08:36 AM
Lohus's Avatar
Lohus
It dims after headlights on despite of the light conditions (light sensor)?
Can somebody measure the voltage on the brown wire of the clock assembly when the headlight is on and off?
Old May 28, 2009 | 09:03 AM
dojoman's Avatar
dojoman
I don't think you will get your answer. Don't we need to remove the Nav unit out and find which connector in order to find out? Does your clock not dim when you turn on the headlights?
Old May 28, 2009 | 09:16 AM
Lohus's Avatar
Lohus
No, you dont need to remove nav unit, just remove clock assembly (as you do when you want to change the navi dvd disk), and just measure the voltage on the brown wire...
My clock not dims. The strange thing is that in the NAVI edition there seems to be two separate wires for dimming, one for the emergency button dimmer, and one for the clock. In NON-NAV edition, there one common wire for that...
Old May 28, 2009 | 09:18 AM
dojoman's Avatar
dojoman
I'll let someone else answer it since I hate taking out the clock unit.
Old May 28, 2009 | 10:05 AM
Lohus's Avatar
Lohus
Practice makes perfect...
Old May 29, 2009 | 04:32 AM
tex2670's Avatar
tex2670
NO--it dims when the IP and nav dim. But, if you twist the dimmer **** to turn the IP lights down all the way, I think the clock stays lit, but at a lower intensity than during the day.
Old May 29, 2009 | 08:12 AM
Lohus's Avatar
Lohus
Well, now we know that this brown wire is definitely stands for the illumination of the clock. The one small detail left undisclosed - the voltage on this wire...
Slickcam
GS - 1st Gen (1993-1997)
15
Feb 4, 2016 03:15 PM
macjac69
Aug 23, 2014 11:10 AM
hemogoblin
Nov 29, 2007 05:36 AM
Nando
Mar 16, 2005 06:46 PM
