AGGRESSIVE ISX50 wheel thread
Old Jun 13, 2011 | 02:16 AM
  #1231
stanced's Avatar
stanced
Good choice Josh, I almost ordered the same wheel, diff color scheme through VIP MODULAR a couple weeks ago. That fitment is on point!
Old Jun 13, 2011 | 06:30 AM
  #1232
Mv350's Avatar
Mv350
josh the setup turned out great!
Old Jun 13, 2011 | 12:39 PM
  #1233
JoshIS408's Avatar
JoshIS408
- - G T V I P - -
Thanks for ur help mv
Old Jun 13, 2011 | 02:43 PM
  #1234
TrancEpimp's Avatar
TrancEpimp
^^ fresh as f @(* ck
Old Jun 13, 2011 | 03:10 PM
  #1235
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
yeah love the new set-up Josh
Old Jun 13, 2011 | 05:29 PM
  #1236
Rash's Avatar
Rash
hmm
Josh, now I can finally say your car is one of my favorites. I love those wheels!
Old Jun 13, 2011 | 05:55 PM
  #1237
Dimitri's Avatar
Dimitri
Originally Posted by JoshIS408
Dude, this looks amazing! I didn't see it posted, what are your wheel specs? Also, what brand/model are they?
I just ordered 19x9.5 +22/19x10.5 +22 rear for my IS. I also ordered megan rear camber arms, but do I need the megan rear toe arms? Do you guys run them or is stock sufice? I want to fit a 265/30 on the rear.
Old Jun 13, 2011 | 06:06 PM
  #1238
2IS 'R' US's Avatar
2IS 'R' US
Looked through the whole thread and saw posts about 18x9+29 with 225/40/18 tires, but did anyone actually run that size wheel in the front? If so any rubbing? I've got an AWD and found a used set of Advan RS's in that size, soooo tempted to get them if I won't have any rubbing issues
Old Jun 13, 2011 | 06:44 PM
  #1239
Mv350's Avatar
Mv350
rear camber arms will do fine, and a 265/30 will stretch and fit perfectly with a slight pull(not really noticable) and roll the front also shave the fender bump tab. lower enough to tuck at least the top 1/3rd of the tire. adjust camber to roughly -4.5* or more in the rear, and roughly -3* to -3.7* in the front...i prefer more haha
Old Jun 13, 2011 | 06:45 PM
  #1240
Mv350's Avatar
Mv350
just roll the fenders. and youre set. youll have to mold the fender liner a bit
Old Jun 13, 2011 | 07:25 PM
  #1241
2IS 'R' US's Avatar
2IS 'R' US
Hmmm, if I go 18x8.5+29, would I still need roll fenders and mold the liner? Thanks Mv!
Old Jun 13, 2011 | 08:06 PM
  #1242
JoshIS408's Avatar
JoshIS408
- - G T V I P - -
^ Yeah +1 what MV said. Run -4 in the rear and - 3 in the front if you can and you should be fine. Id also order the toe arms this way you can Zero that out so you get even tire wear when you align the cars. Megan sells 3 different arms. Only the camber and toe are the important ones, the last ones really for show.
Old Jun 14, 2011 | 06:08 AM
  #1243
Mv350's Avatar
Mv350
with that offset, the fronts will only matter when you drop it and how low you drop. the lower you go the more youll rub and catch the fender. if you have just the top of the tire tucking or a 1 finger gap youll be ok.
Old Jun 17, 2011 | 08:55 PM
  #1244
OOO_ROB's Avatar
OOO_ROB
What mods are needed to run 19x8.5 +15 19x10 +20? tires are 225/245
Old Jun 18, 2011 | 12:04 AM
  #1245
rich250x's Avatar
rich250x
depends on your drop but most likely fender roll/shave, pushing back fender lining those are pretty low offsets
