AGGRESSIVE ISX50 wheel thread
Old Jul 26, 2010 | 08:58 AM
  #811
IS25Heaven's Avatar
IS25Heaven
245.35.19 on my 9.5 + 22 stretched well. But u are gonna 10.5 +22 so i think its prob best to run generals.
i know that this guy with the black tl is running v12s.
http://www.stanceworks.com/forums/showthread.php?t=8863
Old Jul 26, 2010 | 10:29 AM
  #812
Mv350's Avatar
Mv350
tires are on the way, wheels arebeing painted very shortly
Old Jul 28, 2010 | 10:11 PM
  #813
Mv350's Avatar
Mv350
test fit i know the car isnt on the ground but i had to raise it back up so they could take the car to the exhaust shop and go into paint to have the doors blended and the rear bumper painted again cause the base coat was a little light on the first pass.
Old Jul 29, 2010 | 06:08 AM
  #814
Gustavo250's Avatar
Gustavo250
NOW is aggressive, Good job bro
Old Jul 29, 2010 | 06:18 AM
  #815
Mv350's Avatar
Mv350
thank you sir
Old Jul 29, 2010 | 06:38 AM
  #816
Phil888's Avatar
Phil888
^^WOW even too crazy for me!! Camber that shtt and it'll be banging like a mother! hmmm whats your offsets??
Old Jul 29, 2010 | 06:40 AM
  #817
datplayaz's Avatar
datplayaz
what size did you end up going? 245/35?
Old Jul 29, 2010 | 07:15 AM
  #818
Mv350's Avatar
Mv350
10.5+22 and its camber. its just not on the ground in that pic. i forgot to take a pic when we had it off the lift
ya i went with a 245/35
Old Jul 29, 2010 | 09:14 AM
  #819
ohiois350's Avatar
ohiois350
hi everyone! I am thinking getting 20x9.5 with 35mm offset up front, and 20x10.5 with 37mm offset on back, what tire size do you guy recommend, i have the rear rolled about almost 1 inch allready. so what the front tire size without rubbing the fender? and what is the rear tire i can put on with allready rolled fender? thanks
Old Jul 29, 2010 | 09:39 AM
  #820
badx33's Avatar
badx33
loooks dope bro....
Old Jul 29, 2010 | 10:03 AM
  #821
Mv350's Avatar
Mv350
225/30
265/30
mold the front liner and bumper tab. because they are 20's youll have to do almost the same mods as if you were slammed on 19's
Originally Posted by badx33
loooks dope bro....
thanx man
Old Jul 29, 2010 | 10:08 AM
  #822
ohiois350's Avatar
ohiois350
i am not going to drop do you think 235- 30 should be ok? right now i am running 245-30-20 with 42 mm offset and it ok, if iam going to switch to 20x9.5 with 35mm offset and run 235-30 should be ok? without rubbing the fender? i mean fender, not the tab? thanks
Old Jul 29, 2010 | 10:13 AM
  #823
Mv350's Avatar
Mv350
ya you should be ok with a 235/30. still might need to heat your fender liner and push in with a flat rock and then spray it with ice cold water. its not hard.
Old Aug 11, 2010 | 09:29 PM
  #824
merfman's Avatar
merfman
will 18x8 and 18x9 +22 offset all around, with the oem tires (225/45 and 245/45?) fit ok. im droped on eibach pro kit, and i dont want to modify my fenders. please let me know, thanks much.
Old Aug 11, 2010 | 10:29 PM
  #825
Mv350's Avatar
Mv350
tires might be too big, you might have to go to 235/40 in the rear maybe 245/40
