pandy that's actually really aggressive on our cars. you won't see too many people running that set up. johnnyboy calviin weirdazndu are the ones i can think of who aren't on air right now
EDIT: THAT S#!T LOOKS GANGSTER^^^^^^^^^^^^^^^^^^^^
Originally Posted by steezy
Yes boss i know. Just trying them on for a day or two. Ill do body work as soon winter break starts.
just giving you a hard time, i know youz guyz in HI drive low or not at all
Originally Posted by pandy_88
9.5+22 with 225 won't rub right? Cuz I ran 235/35 and it rubbed my plastic liner in the front.
i ran 19x8.5+15 with 215/35 with no rub and i was dumped on coils. The 2IS is very picky up front. believe it or not when going 19's if you want to go aggressive up front you really only wanna go to a 9" wide wheel because you can run a 215/35. i drove this low and could crank a full u turn.
my setup was 19x8.5+15 which is roughly = 19x9.5"+27. i easily have room to fit that 5mm spacer to get the offsets equal. see picture above. ideally on the 2IS an aggressive front with coils should be about 19x9+16 with a 215/35.
Those offsets and widths are actually pretty common now. People are actually running more aggressive..
