torque specs for aftermarket wheels
Old Jul 11, 2008 | 12:35 PM
silversx's Avatar
silversx
Default torque specs for aftermarket wheels
is it the same as stock wheels?? 76lb/ft?
thanks
Old Jul 11, 2008 | 12:38 PM
T-Rex06's Avatar
T-Rex06
Ho Motorsports
That's the amount of torque I use for my aftermarket rims.
Terrance
Old Jul 11, 2008 | 02:09 PM
PHML's Avatar
PHML
Master Thread Closer!!
yah....seems good at 76.
ever wondered how they come to decide on 76? why not 75? must be scientifically derived.
Old Jul 11, 2008 | 03:42 PM
ISF_GG's Avatar
ISF_GG
Use a good torque wrench, and you'll be set to go. I usually do mine at 78, I read somewhere that it was ok.
Old Jul 11, 2008 | 04:31 PM
ba-b4's Avatar
ba-b4
I never use a torque wrench just tighten with a regular cross wrench as hard as I can. Any bad side about doing that?
Old Jul 11, 2008 | 07:16 PM
javyLSU's Avatar
javyLSU
2IS OG
^In addition to the possibility that you might not be able to get your lug nuts off manually if needed, you run the risk of damaging your studs from over-torquing the lug nuts.
Javier
Old Jul 12, 2008 | 01:54 AM
ba-b4's Avatar
ba-b4
^^ I can damage the studs by manually torquing them? I didn't know that. I figured since many shops use impact wrenches anyway that those are way more powerful than what I can do manually anyway and they do that to cars day in and day out.
Old Jul 12, 2008 | 03:52 AM
nabbun's Avatar
nabbun
that's only if you keep wrenching with that impact wrench long after it stops spinning. what ur supposed to do is stop the moment it's on tight (no more lug rotation). after all 5 on on tight, u use the torque wrench to make sure it's spec'd out correctly. Try not to over torque cuz u can do what Javy said and you can damage the lugs and rims
Jaysoo
Oct 5, 2014 05:16 PM
ScBouncE
Jan 27, 2014 06:58 AM
Kaban
Wheels, Tires & Brakes Forum
Sep 24, 2005 07:41 PM
leosls400
Feb 4, 2005 01:12 PM
lawman
Jan 24, 2003 07:41 PM
