Does anyone know how to remove tail lights???//
Old Apr 15, 2008 | 06:16 PM
dajwilson's Avatar
dajwilson
Default Does anyone know how to remove tail lights???//
I've removed the 3 bolts securing the corner tails but there is something that is still holding them in there. The inside tails look fairly straight forward but I'm having problems with the corners.
Old Apr 15, 2008 | 09:10 PM
cm09578's Avatar
cm09578
For the outside lights you have to pull pretty hard to get them out.....there is a slot on the outside of the light....after the 3 inside screws are out pull straight back on the light it will come out.
Old Apr 15, 2008 | 09:14 PM
dajwilson's Avatar
dajwilson
Thanks for the response. I'll give it a try.
Old Apr 24, 2009 | 09:20 PM
radicalrev's Avatar
radicalrev
i need to remove them too...
so is just hold by 3 screws and 1 clip at the side (white clip)?? I see there is one yellowish clip too near the screws and was wondering what is that and if I need to pry it out??
Old Apr 24, 2009 | 09:54 PM
acefalcon2's Avatar
acefalcon2
no prying just pull it.. the clip would come out on it's own when you pull..use extra strength... wah bos baru beli apa nih harus kluar2 segala? IS-F Tails?
Old Apr 24, 2009 | 10:09 PM
YooNiBaLL's Avatar
YooNiBaLL
tape off the sides around the taillights so that if u pull it too hard, u dont accidentally scratch it.
Old Apr 25, 2009 | 12:29 AM
projectdna's Avatar
projectdna
a good idea might be to unplug the harness BEFORE pulling the corner tails out.
the corner tails will come out after removing the three screws, but it'll take a bit of prying.
Old Apr 25, 2009 | 01:36 AM
radicalrev's Avatar
radicalrev
lol...im just afraid i break anything...is there any tab holding the side of the tail lights?
Old Apr 25, 2009 | 11:13 AM
ISCjonny's Avatar
ISCjonny
nope.. no tabs.. just 3 screws as mentioned above.. the thing on the side is like a rubber plug.. so just pull straight back..
Old Apr 25, 2009 | 11:41 AM
Lets Drive's Avatar
Lets Drive
Hehe, you won't break anything. You just have to put a little muscle into it, once you remove the screws and harness from the lights. You'll laugh once you realize how easy it is.
Old Apr 25, 2009 | 11:45 AM
SeOuLiS250's Avatar
SeOuLiS250
yank the thing out..lol
just make sure you take off the 3 screws that are mentioned above
Old Jul 13, 2011 | 05:53 PM
ThermonMer's Avatar
ThermonMer
in the middle of doing this now. there is a secondary harness on the outer taillight that will NOT unclip. ive been trying for over a ****ing hour
Old Jul 13, 2011 | 06:50 PM
ThermonMer's Avatar
ThermonMer
ugh, finally got it.
ganka
Jun 19, 2018 10:40 AM
ibrewdou
Nov 18, 2017 08:09 AM
Lveyolfe
Feb 28, 2017 11:05 AM
hybridanim
Nov 5, 2009 10:26 AM
the_ez_rhino
Sep 12, 2002 04:26 PM
