Leaking Air!!!
Old Mar 28, 2008 | 03:08 PM
italiandud's Avatar
italiandud
Default Leaking Air!!!
So i got my wheels installed about one month ago and a few weeks ago i realized that one of my tires was low on air so i filled it up. But now i realized that both of my front tires have 20psi when they should be at 40psi... Im guessing that i have leaks. I am running 19' Iforged equips. Do any of you guys also have problems with your aftermarket wheels?
thanks
Old Mar 28, 2008 | 03:22 PM
genki's Avatar
genki
probably the valve is not shut. it happened to me on one of my wheels last time. you can fix it with a screwdriver.
Old Mar 28, 2008 | 03:41 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
my OEM rim loses air (~10psi) every 2-3 weeks..... I am suspecting it's the seals from the TPMS........
Old Mar 28, 2008 | 07:12 PM
sinister2c's Avatar
sinister2c
it could be 3 things... the seal on the lip,face, barrels is bad, valve stem seals, or ripped bead on the tires. stick the wheel in a pool or tub to see where theres a leak.
Old Mar 29, 2008 | 02:49 AM
IS_NIICE's Avatar
IS_NIICE
i think it's because your car is too high.
Old Mar 29, 2008 | 09:00 AM
josephdoc's Avatar
josephdoc
If the wheels are new, 99% chance the leak is at tpms module + stem (extension?) area.
Check your tire shop if they replaced the rubber grout on tpms stem. It is a rubble placed at the contacting surface bteween the wheel and the module. There is a "maintenance kit" for tpms module and it's needed when remouting tires. A good shop should use the kit and charge about $10 MORE on each wheel for this process...
Mankind did not drive with TPMS for last 2,000 years, and we have to get used to it.
Joseph
Old Mar 29, 2008 | 11:56 PM
Premier's Avatar
Premier
I had a similar problem. The right rear wheel needed to be filled with air like every month or so. Turns out that there was a nail in the wheel.
Old Mar 30, 2008 | 12:02 AM
ek9vboi's Avatar
ek9vboi
listen to him. i need to check mine to see why im leaking on one of my wheels before something goes bad.
Old Mar 30, 2008 | 09:48 AM
Brian231's Avatar
Brian231
This is possibly the explanation. I was told that the TPMS seal should be replaced anytime it is removed from the rim. When I had my new rims installed at Discount Tire, they stressed the new seal kit. I said absolutely for only $20. Tire Rack sells this kit as well.
Old Mar 30, 2008 | 05:54 PM
passnu2's Avatar
passnu2
+3 Its probably one of these. You need to take it back to the tire place so you have documentation just incase anything happens to your new tires. should be a quick easy fix! they do need to reseal the TPMS when and if they removed them from your OEM rims.
JamalGS300
Suspension and Brakes
Feb 5, 2015 12:13 AM
gsean400
Feb 24, 2014 12:50 AM
SCinSin
Nov 23, 2012 07:01 PM
boss22
Nov 25, 2011 07:25 PM
lexusrott
LX - 3rd Gen (2008-2021)
Feb 9, 2008 02:28 AM
