Need help! (power window problem)
Old Mar 6, 2008 | 01:01 PM
dat-is350's Avatar
dat-is350
Default Need help! (power window problem)
I was deadening my doors and now the automatic windows don't work. Does any one know what the problem is?
Old Mar 6, 2008 | 01:13 PM
slee18's Avatar
slee18
you disconnect battery when you did that?
Old Mar 6, 2008 | 01:17 PM
Brian231's Avatar
Brian231
There is a thread that describes how to re-set your power windows after the power is cut. Do a simple search, this was a common fear amoung CL members but is no big deal and takes under a minute to rectify.
Old Mar 6, 2008 | 01:23 PM
slee18's Avatar
slee18
here is the link https://www.clublexus.com/forums/sho...d.php?t=291026
Check out your owners manual too.
Still baffled why you would disconnect the battery take the door panels off.
Old Mar 6, 2008 | 01:29 PM
Brian231's Avatar
Brian231
I believe you to go to each car window and push the window button up and down and that for some reason let the drivers side door once again have control of those windows.
Old Mar 6, 2008 | 01:53 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
you need to reset the windows.....
Old Mar 6, 2008 | 02:14 PM
is250manny's Avatar
is250manny
lol.
i had this happen to me. luckily i figured it out myself.
Old Mar 6, 2008 | 02:23 PM
josephdoc's Avatar
josephdoc
It's alright, everyone has its first time.
Old Mar 6, 2008 | 02:32 PM
wolverine's Avatar
wolverine
do we have airbags on our doors? if not then i dunno...
Old Mar 6, 2008 | 02:34 PM
Brian231's Avatar
Brian231
No door airbags like Mercedes or Beemers, simply A piller Curtain front and rear, knee airbags, side front seat SIPS bags and the standard steering wheel and passenger bag in the dash.
Old Mar 6, 2008 | 03:40 PM
dat-is350's Avatar
dat-is350
I knew how to reset it. It's just I thought you only had to do that if you disconnect the battery. Weird. I got it fixed though. Thanks alot guys!
Old Mar 6, 2008 | 04:02 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Not just disconnect the battery. If you disconnect the switch assembly in the driver's side door you'll need to reset them. AMHIK.
edborges03
Apr 22, 2021 04:01 AM
akhosravi
Jul 26, 2019 07:10 AM
roccodog
Feb 17, 2019 03:41 PM
jbyham
GX - 1st Gen (2003-2009)
35
Feb 7, 2016 01:40 AM
ahmed24
Feb 12, 2008 01:56 AM
