HID Install question. HELP!
Old Mar 1, 2008 | 11:15 AM
08mica's Avatar
08mica
Default HID Install question. HELP!
I am in the process of installing a set of HID's and the bulb will not fit into the housing. I have an 08 with halogens (obviously). I have H11 bulbs, but the plastic housing that screws in is way too small. See pics below.
Are these the right bulbs? They say H11 on the tags, box, bulb itself. Where did I go wrong?
Old Mar 1, 2008 | 11:39 AM
cliffud's Avatar
cliffud
Former Vendor
The pics are pretty small so it's hard to tell but it looks like you need to take off that semi-transparent ring off the H11 HID bulb.
Old Mar 1, 2008 | 12:47 PM
08mica's Avatar
08mica
I'll fix the pics. But the black ring is way smaller that the other bulb.
Old Mar 1, 2008 | 01:43 PM
radicalrev's Avatar
radicalrev
yeah sometimes the bulb dun fit in perfetly..sometimes its just too big....u gotta modify the ring to fit in..like i did when i bought the Volt Hid...
Old Mar 1, 2008 | 03:54 PM
08mica's Avatar
08mica
New pic. The "key" part that locks in is too small. Now what?
Old Mar 1, 2008 | 06:39 PM
AK-47's Avatar
AK-47
You might got the wrong size. and the pic is not clear
Old Mar 31, 2008 | 04:45 AM
jdmiscool's Avatar
jdmiscool
Did you ever figure this out???
Old Mar 31, 2008 | 06:50 AM
Brian231's Avatar
Brian231
It is possible that the seller did not send H11 bulbs. The base on the H11 should not be that small.
bluestar
Lighting
Aug 2, 2011 09:19 PM
Gilky115
Nov 5, 2010 07:56 AM
IneedLexus
Feb 12, 2010 08:42 PM
rominl
Lighting
57
Jun 9, 2005 12:35 AM
LEXISM
Lighting
15
May 24, 2005 03:52 AM
