First Service: Question
As for philip doing his own... it costs him more thou cuz he breaks stuff
I suggest you read the manual first *tells ya to put it on recirculate
* and if its not in the manual, check the sticky FAQ *tells ya to put it on recirculate there too
*, is an example.
I just got my 2008 and made it to the tire rotation page in the owner's manual earlier tonight.
Lexus' 30-day/1,000 mile and 6-month/5,000 mile services are complimentary.
- 2WD models with 16-inch tires and AWD: rotate front to back, keeping the driver's side tires on the same side and the passeger side tires on the same side.
- 2WD models with 18-inch tires: rotate side to side, keeping fronts on front and backs on back.
- 2WD models with 17-inch tires: cannot be rotated
The only winner here is the IS250 AWD since you can swap the entire rim & wheel from front to back every 5k miles or oil change...
Generally speaking, As long as the tire does not say "This Side Out Only" & "This Side In Only", it can be rotated side to side when dis-mounted..
Especially if they are directional as well..
I may consider swapping my fronts & rears side to side around 10k or 15k miles.. depending how the wear looks..
But the whole idea of dis-mounting, re-mounting & re-balancing 4 Liquid Graphite Wheels, just doesn't sit well with me...
IF everything wears even with my driving habits: 90% fwy / 10% Local, I hope these tires will last me approx 25k-30k miles... (without rotating my Bridgestone Turanzas)
Just looking foward to buying & mounting new tires when needed...
Joe Z
Joe Z
