Volk +35 offset ?
Old Jan 6, 2008 | 10:54 AM
z4frosik's Avatar
z4frosik
Question Volk +35 offset ?
Hey i just received my new "mooncakes" in the mail, VOLK RE30's and they are 18x9.0 +35. I mostly see owners putting +30 in the rear, does anyone if this will present a problem. If so any tip/advice would be greatly appreciated. Also will the addition of lowering springs affect the wheel's offset fitment ?
(ill add pics as soon as my sis comesback with my cam)
Old Jan 6, 2008 | 11:06 AM
Signal_jp's Avatar
Signal_jp
what are you complete specs 19x9 rear +35? or is that the front? a 19x9 +35 rear will not be completely flushed with the fenders but on the plus side you can run a wider tire or lower the car with no rubbing problems.
Old Jan 6, 2008 | 11:16 AM
z4frosik's Avatar
z4frosik
They are allaround 18x9 +35.
Old Jan 6, 2008 | 12:52 PM
DJKIBBLES's Avatar
DJKIBBLES
I think it is better if you bought a staggered setup, since our cars are staggered.
Old Jan 6, 2008 | 01:10 PM
pocky's Avatar
pocky
mooncake master
You might run into rubbing issues for those mooncakes on the front. The rear is fine.
Old Jan 6, 2008 | 01:43 PM
Lextasy89's Avatar
Lextasy89
his car is AWD!!
Old Jan 6, 2008 | 02:00 PM
Irishman06's Avatar
Irishman06
CL Folding 25,000
AWD IS's do not have staggered fitment.
Old Jan 6, 2008 | 02:07 PM
dat-is350's Avatar
dat-is350
He got AWD noob!
Old Jan 6, 2008 | 02:20 PM
Swisha's Avatar
Swisha
I think it should be fine since its 18 and not 19x9. Just run 225/35 or 30 tire to be safe
Old Jan 6, 2008 | 03:42 PM
ReLexin's Avatar
ReLexin
so your rears look more flush with the fenders i would recommend some spacers. It will make it look more aggressive. I do also have an AWD, but i am running a staggard set up. 20x8.5 front +32 offest and the rears are 20x9.5 with a +36 offset.
Old Jan 6, 2008 | 07:53 PM
z4frosik's Avatar
z4frosik
thanks alot for all your advice, any idea where i can get a cheap good spacer to make it +36 in the back :x?
Old Jan 6, 2008 | 08:42 PM
Lextasy89's Avatar
Lextasy89
you said it was +35 all the way around...
any spacer would make the offset lower..causing the wheel to stick out more.. i dont think there is any way to make it +36
Old Jan 6, 2008 | 09:32 PM
javyLSU's Avatar
javyLSU
2IS OG
Your wheels will fit perfectly, no need for spacers. My current setup is 18x8.5 +33 front and 18x9 +33 in the rear, and it fits the IS like a glove. The front won't rub, and you'll be almost perfectly flush in the rear. Of course, some of this depends on what size tires you plan on running. This is one of my favorite websites for comparisons like this.
Make sure to post pics when you get them on!
Javier
Old Jan 6, 2008 | 09:57 PM
z4frosik's Avatar
z4frosik
O, great news thanks javier i will be sure to post pics asap.
Lucid
Mar 2, 2009 02:38 PM
lowKut
Feb 17, 2009 08:50 PM
zoomtt
Feb 9, 2007 09:08 PM
jbbnet
Wheels, Tires & Brakes Forum
Feb 7, 2003 12:29 AM
