Recommend a good Bluetooth Cellphone from Cingular?
Old Oct 8, 2007 | 09:54 PM
Coconut's Avatar
Coconut
Default Recommend a good Bluetooth Cellphone from Cingular?
I currently have an unlocked original LG Chocolate (KG800) GSM cellphone that I'm using with Cingular. Needless to say,the bluetooth functionality sucks when paired with my car. The bluetooth connection connects about 75% of the time and the only thing that works is speaking through the speaker system and using the steering wheel button to pick up phone calls. I can't dial phone numbers from the car and see current battery life or signal strength.
Can anyone recommend a good Bluetooth cellphone from Cingular (GSM)? Basically just a good solid BT cell to pair with the car. This is the criteria:
1. very clear (strong signal strength)
2. good BT connection with the IS250 (reliable connection each time)
3. full BT functionality from the car (phone book, number pad, shows signal/battery bar)
Old Oct 8, 2007 | 10:52 PM
CAIFAN_64's Avatar
CAIFAN_64
here is the lexus site, it tells you what phone/carrier is compatible with the IS250/350
http://lexusbluetooth.letstalk.com/p...iew=1&model=IS
Old Oct 9, 2007 | 08:26 AM
proxy's Avatar
proxy
I have an iPhone, and it seems to work great with the IS. No problems with signal strength, it syncs up a few seconds after I start the car, and shows the battery bar. It also shows caller ID when the phone rings and all that good stuff.
Before the iPhone, I had the Samsung Blackjack. That was a piece of crap. No integration what-so-ever with the IS other than headset usage.
Ca1vN
Mar 4, 2020 10:32 PM
cap2045
Mar 29, 2014 11:49 AM
NeilB25
RX - 3rd Gen (2010-2015)
May 26, 2010 09:30 AM
yov6cam
Jul 25, 2007 10:00 AM
dfw350
Jul 12, 2006 09:46 PM
