forgot to turn off headlight
Old 07-19-07, 06:42 AM
SonnyIs350
SonnyIs350's Avatar
they will go og in 30 sec.
Old 07-19-07, 07:31 AM
Buds
Buds's Avatar
lmao this thread was pretty funny.
Old 07-19-07, 09:24 AM
ULTiMaX99
ULTiMaX99's Avatar
i think it's an LPS setting to set how long you want your headlights to stay on after you lock the door. default is i believe 30 seconds. the headlights will also turn off immediately if you click the lock button on your remote after locking it the first time. if you turn off your headlights then shut off the engine n turn the headlights back on... the headlights won't automatically shut off in 30 seconds.
Old 07-19-07, 09:39 AM
tex2670
tex2670's Avatar
how do u get it to go off immediately, and not stay on 30 sec? can this lps only be set by the dlr?
Old 07-19-07, 09:53 AM
ISbb
ISbb's Avatar
the light will only gone off when you open the driver side door... what if you didn't open the driver side...?
Old 07-19-07, 09:55 AM
t.is350.h
t.is350.h's Avatar
Did you guys know that if you press the lock button on the key fob twice it will turn off the light?
Old 07-19-07, 10:14 AM
Buds
Buds's Avatar
This is very true!
Old 07-19-07, 10:15 AM
Magellan
Magellan's Avatar
I also noticed that if you leave the trunk open (and I guess a door too) the lights will not turn off in 30 seconds. The car is smart enough to know we’re emptying groceries or something and may need the light. I don’t know if they eventually turn off anyway. I’ve just closed the trunk before leaving the area so as not to run down the battery.
Old 07-19-07, 10:19 AM
Buds
Buds's Avatar
The lights will eventually turn off. I do this everyday when I get home from work. I pull into the garage and my lights turn on. I pop the trunk, get out, lock the car and go get my briefcase and stuff out of the car. The lights remain on the whole time. I shut the trunk and walk away. The lights turn off 30-45 seconds later.
Basically, no matter what the scenario, the car WILL NOT allow you to leave your lights on for extended periods of time while the car is off and locked.
Old 07-19-07, 10:23 AM
Pnuge88
Pnuge88's Avatar
mine turns off in 30 secs.. automatic position or on position.... only cause i set it that way but normally i think its 1 minute or 45 seconds
AMauriG
02-24-18 02:06 PM
Joetc
05-18-17 07:51 AM
batchelor
NX - 1st Gen (2015-2021)
11-07-16 12:58 PM
RamshakleZ
09-26-12 07:35 AM
pakattack
01-18-11 02:34 PM
Quick Reply: forgot to turn off headlight
