Listed item# for dustcovers
Subscribe
May 17, 2007 | 04:51 PM
For those of you looking for the dust covers..
(Stole this picture from AzNrAcEr, Sorry)
ITEM #'s
8113653240-COVER, RH
8117653240-COVER, LH
I was quoted from lexus-parts.com $20.02 for both covers.
Reply 0
May 17, 2007 | 05:06 PM
Good find! Very interesting, but I think the key is trying to seal it for water vapor.
Are those originally made for 2IS, or those are just some parts that you found would perfectly fit?
Reply 0
May 17, 2007 | 05:56 PM
Quote: Good find! Very interesting, but I think the key is trying to seal it for water vapor.
They are the OEM dust covers. I thought it would be good to have them in case something would go wrong in the future. If anything would go wrong back in and take it to the dealer because I have drilled holes in mine to fit my HID cables.
Reply 0
May 17, 2007 | 06:31 PM
Thanks for the info, might need it in the future.
Reply 0
May 17, 2007 | 07:14 PM
thats why i didnt drill a hole in my factory dust covers, i just used duck tape
Reply 0
Jun 22, 2007 | 02:57 PM
For the record, those part numbers are incorrect. Those are for the high beam area covers.
Reply 0
Jun 22, 2007 | 04:03 PM
Quote: For the record, those part numbers are incorrect. Those are for the high beam area covers.
Oh no, that sux... Any one confirm that??? I might be needing to know the part numbers for the low beam ones...
Reply 0
Jun 22, 2007 | 04:14 PM
Those are the High beam covers.
The correct part numbers are:
81135-53270.
I also went ahead and bought me the headlight connector as well, so there is no chance those connectors come off while I am driving. If you look at your headlights, there is a harness that connects the headlight bulbs to the rest of the harness. Its a small 2 pin connector that was gray for my car. The part numbers are listed below.
90980-11148 for the connector
82998-12340 for the slice connectors and wires that go into the 90980-11148.
You will need 2 of the slice connectors for each pin. One thing to note that these appear to all have toyota part numbers, so it may be cheaper just to get them at a toyota dealer.
Reply 0
Jun 22, 2007 | 04:25 PM
Mines look different...OEM HID has different dust covers?
Reply 0
Jun 22, 2007 | 04:29 PM
The high beams have a curve in them, the flat ones are the 53270.
Reply 0
Jun 23, 2007 | 06:43 AM
81135-53270.
Haha yea, I realized that after I opened up the box. Is that part number the same for both sides?
Reply 0
Jun 23, 2007 | 06:45 AM
Thanks for the updated info. Someone should fix the first post so no one else gets confused. I'll PM a mod.
Reply 0
Subscribe
