dvd watching??
Old Jan 23, 2007 | 12:58 PM
drewj12's Avatar
drewj12
Default dvd watching??
I just have a question as to how good the picture quality is on the nav screen when watching dvd's? anyone have any pictures they can put up? and also for the ML system would movies in dobly 5.1 be upscaled to 7.1? thanks.
Old Jan 23, 2007 | 01:09 PM
PhilipMSPT's Avatar
PhilipMSPT
Cycle Savant
As for the picture quality, it's as good as it's gonna get for a nine inch screen.
It's very bright and clear; just make sure that if you watch movies at night, you have the light intensity in "day" mode...
Old Jan 23, 2007 | 03:52 PM
drewj12's Avatar
drewj12
k, thanks. as for the surround sound anyone...?
Old Jan 23, 2007 | 09:09 PM
r1lee's Avatar
r1lee
unfortunately i do not have the ability to own a ML version of the car.
But upon checking the Marklevinsonlexus.com web page, unfortunately you cannot.
The Deck only supports Dolby 5.1 and DTS 5.1 For the system to properly support a 7.1 setup, the deck needs to be DD-EX and/or DTS-ES.
Hope that helps.
Old Jan 24, 2007 | 03:45 AM
cpsmith516's Avatar
cpsmith516
what do you mean unfortunately you cannot? surround sound is DD5.1 and DTS5.1, DTS-ES, and DD-EX are extensions that add another channel and are not the only two standards considered to be surround sound. your statement is confusing on so many levels my brain just collapsed.
Old Jan 24, 2007 | 07:31 AM
r1lee's Avatar
r1lee
The OP is asking if it's possible to get 7.1 channels out of the ML system. I can see why he wants this as there's enough speakers to do so. Unfortunately the ML deck does not support anything more then 5.1, so therefore the extensions are not supported for him to get any EXTRA CHANNELS therefore 7.1 is currently IMPOSSIBLE.
I've never stated in my statement that DD-EX and DTS-ES were the only surround sound options. I just stated that those are the formats he needs supported to get to 7.1. You are confusing me now!
But if you are talking about other surround sound formats like Logic7, then sorry to confuse you. The OP is asking for what the ML deck supports. Unfortunately even though ML is a division of Madrigal( I think it's called Harman Specialty Group now), the car does not support Logic7 or any other surround sound format.
DrewJ12:
your out of luck right now. You just need to live with the 5.1.
Old Jan 24, 2007 | 08:00 AM
HKS350's Avatar
HKS350
Whats the big diff.between the ML system and standard NAV system.And can you unlock the program feature in the standard NAV to play dvd?
Old Jan 24, 2007 | 10:22 AM
misterbear's Avatar
misterbear
Default standard dvd system
Diff between ML and standard - 7.1 sound in ML, ability to play dvds in ML.
For standard you can't play dvds - and there is no simple hack to make it do so. There was some thread out there that outlined someone's experiences in hacking the standard dvd player - he had to rip of the center console, install a NAV-TV module ($500+ for the part), route the connections to a switch that he flips to switch between Nav hack and OEM connections (since using the Nav hack, the rear camera and nav don't work when you switch from TV - I could be wrong on this part, I'm going by memory).
In the end it came out to be like $800+ for parts, excluding labor (and it seemed like ALOTTA labor).
Hmm...$800+ for parts excluding labor or $900-something for a factory integrated ML DVD player with 7.1 sound... you make that call.
I'm getting a IS250 in So Cal - ML is not really offered in the packages for the IS250 here. I'm outta luck here unless I want to pursue a similar hack. I'm an Electrical Engineer, but there is no way in hell that I'm going to do this hack - props to the guy that did.
Old Jan 24, 2007 | 11:35 AM
drewj12's Avatar
drewj12
DrewJ12:
alright thanks man, thats all I wanted to know.
lomarica
Feb 27, 2011 12:36 PM
hiendo85
Jan 31, 2011 09:03 PM
jk08
Aug 26, 2008 10:31 AM
aas080
Jul 23, 2007 07:39 AM
IS 350
Nov 16, 2005 01:01 AM
