Climate Settings
Old May 11, 2006 | 06:21 PM
IXLRS's Avatar
IXLRS
Default Climate Settings
Just curious how others have set up there IS climate setting.
Do you go with the Auto mode and forget it?
What about air conditioning? I think in the auto setting the AC is on most of the time. Seems with auto the fan at a higher speed than I would choose otherwise.
Comments?
Old May 11, 2006 | 07:08 PM
kenne74's Avatar
kenne74
I have mine set to auto and the fan speed is set to med or at least that is where it stays. Just adjust the fan speed if it is blowing too hard.
Ken
Old May 11, 2006 | 07:17 PM
phish2112's Avatar
phish2112
Comments?
i noticed this today. on auto the fan blows harder than even when I have it on manual high. and the ac is always on even when i have the temp set at a ridiculously high temp. what gives?
Old May 11, 2006 | 07:47 PM
RealNinjuz's Avatar
RealNinjuz
I have it set to auto and the highest setting.
Its consistently 100 degrees as of late, so if I dont, the leather bakes my ***.
Old May 11, 2006 | 08:40 PM
Bichon's Avatar
Bichon
I had the recirculate/ventilate switchover changed to manual mode at the dealer, because I like to keep the A/C in recirculate mode permanantly when it is humid outside. Before the dealer set that option, the car switched to ventilate as soon as the interior temp dropped close to the set point.
Beyond that, I usually leave it in auto, except when I am using the hands-free phone on a hot day. Due to wind noise being picked up by the microphone (even with the vents pointed down), I'll usually either drop the fan speed or direct air to the floor vents.
Old May 11, 2006 | 09:01 PM
Dabigman's Avatar
Dabigman
The AC runs all the time to dehumidify the cabin and keep the air, hot or cold, comfortable.
Old May 12, 2006 | 04:31 AM
monkeyfarm's Avatar
monkeyfarm
You can leave the climate control in AUTO mode and turn off the AC (just tap the AC button). This is what I typically do when it's cool out... no need to run the AC and use up extra gas, and AUTO will still do all it can to keep the cabin temp at your desired setting.
Old May 12, 2006 | 08:03 AM
IXLRS's Avatar
IXLRS
Really.....I'll verify today...thxs all
Old May 12, 2006 | 01:08 PM
jcreech's Avatar
jcreech
amen, this is what i do. But the auto re-circulate mode is great for the hot days.
Old May 13, 2006 | 07:33 PM
skorpio's Avatar
skorpio
How did the do it? Is it a part of the personalization process?
regards, Bart.
Old May 13, 2006 | 08:32 PM
Bichon's Avatar
Bichon
regards, Bart.
Yes, it's one of the LPS (Lexus Preference System) options.
Jabberwock
Jun 18, 2017 02:32 PM
finalhope
May 29, 2014 05:11 PM
tonyhui
Hybrid Technology
13
Dec 1, 2013 01:00 PM
jay33
Mar 16, 2011 12:51 PM
hegar817
Jan 10, 2008 07:54 AM
